Page 1 of 3 1 2 3
Distributor Cap Blow off #983764
05/01/11 09:43 AM
05/01/11 09:43 AM
Rhode Island
Caparco Offline OP
Caparco  Offline OP
Rhode Island
Having trouble with my Cap blowing off when I get up on the gas to pass or from a stop, Doesn't come right off just one side pops and cocks to the right, throws it way out of time.
Tried to adjust (bend back) the thin metal 'barbie pin' clip, worked a little but soon re-accured. I don't think drilling a vent hole in it is good as presure is good there. right?.. would some Twine burn up in the compatment? What are your thoughts
And yes I don't see anything in the way under the hood would be in the way when the engine lifts from exceleration, seems to be just Presure.
Marcus
~ 72 Dodge Challenger ~
~ 97 Dodge Neon ~
~ 97 Dodge Ram ~
Re: Distributor Cap Blow off [Re: Caparco] #983765
05/01/11 10:05 AM
05/01/11 10:05 AM
BDW Offline
BDW  Offline
How old is the cap? All the newer ones have a vent.
Re: Distributor Cap Blow off [Re: Caparco] #983766
05/01/11 10:06 AM
05/01/11 10:06 AM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
The only things that come to mind are either the rotor is rising and pushing the cap off, or maybe the shaft is bent or the shaft bushing is shot.
I'm curious on this one....
`68 Barracuda 340-S
Re: Distributor Cap Blow off [Re: Caparco] #983767
05/01/11 10:08 AM
05/01/11 10:08 AM
grab some clips from a junk dist & do check rotor fit/clearance on the inside
Re: Distributor Cap Blow off [Re: BDW] #983768
05/01/11 06:19 PM
05/01/11 06:19 PM
Rhode Island
Caparco Offline OP
Caparco  Offline OP
Rhode Island
its kinda new a few years, I took the Points out and put this electronic egnition conversion one everyone was highly recomending it, So there are vents?.. you or anyone have a pic of this?
not even sure where I can get a new clip for the cap, really no data plate or marking on it at all
~ 97 Dodge Neon ~
~ 97 Dodge Ram ~
Re: Distributor Cap Blow off [Re: Caparco] #983769
05/01/11 07:42 PM
05/01/11 07:42 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I've had a parts store rebuilt slant six dist that were poorly remaned. When it was blasted to clean it up, they erroded the caps seating surface and would not allow the cap to seat properly. Vibration from driving around would pop the cap off.
Re: Distributor Cap Blow off [Re: Caparco] #983770
05/01/11 07:42 PM
05/01/11 07:42 PM
Under My Car
Mopar_Country Offline
Under My Car
If it's a Chrysler distributor you can get clips here:
http://www.henryspartsdepot.com/chrysler-mopar-nos-parts/
Re: Distributor Cap Blow off [Re: Mopar_Country] #983771
05/01/11 08:57 PM
05/01/11 08:57 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
caps have a vent, with a little cover over it. there shouldnt be anything making that much presure inside the cap, unless you are getting crankcase pressure leaking up the shaft, into the cap. i suspect you'd see a lot of oil coming up and into the housing, if this was true. snap the cap on and then try to lift or wiggle it off. it shouldnt really move. of it does, something isnt right. i've had junk caps, that just wouldnt mount properly, and could be moved off the dizzy, when clipped down. replacing with a quality cap fixed it for me.
you didnt mention engine size, but if you have a small block, make sure you dont have a broken motor mount. the engine twisting when torqued from a stop, could drive the dizzy into the firewall, and pop the cap. (depending on clearance in your particular car)
Re: Distributor Cap Blow off [Re: Golden-Arm] #983772
05/01/11 10:14 PM
05/01/11 10:14 PM
BDW Offline
BDW  Offline
Re: Distributor Cap Blow off [Re: BDW] #983773
05/02/11 12:27 AM
05/02/11 12:27 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: Distributor Cap Blow off [Re: JohnRR] #983774
05/02/11 12:30 AM
05/02/11 12:30 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
John,ever see gas inside a distributor ?
Re: Distributor Cap Blow off [Re: 62maxwgn] #983775
05/02/11 01:34 AM
05/02/11 01:34 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Vacuum advance diaphram can fail, letting gasoline vapors get into distributor, ignite, and blow cap off. AMC's had this problem mid/late 70's.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Distributor Cap Blow off [Re: 62maxwgn] #983776
05/02/11 08:51 AM
05/02/11 08:51 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No I haven't but I knew as soon as I posted that there would be someone contradicting it .
Think I'll hang in the general section from now on , hippo and penguin talk is getting more interesting by he day
Re: Distributor Cap Blow off [Re: Caparco] #983777
05/02/11 09:17 AM
05/02/11 09:17 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Sounds to me that you have junky dist, where did you get it?
Re: Distributor Cap Blow off [Re: Challenger 1] #983778
05/02/11 01:03 PM
05/02/11 01:03 PM
Under My Car
Under My Car
Take the cap off and try pulling up on the shaft. It's possible the clip is weak or broken and the shaft is riding up the gear.
Re: Distributor Cap Blow off [Re: JohnRR] #983779
05/02/11 01:20 PM
05/02/11 01:20 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Boy John,never knew you were that easily offended. Why do you suppose they vent a cap ? !!!!!
Re: Distributor Cap Blow off [Re: 62maxwgn] #983780
05/02/11 01:25 PM
05/02/11 01:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Boy John,never knew you were that easily offended !!!!!
I'm not offended easily , my memory isn't as good as i thought it was I guess, I need to just sit back and and let others that have the answers do the talking, maybe I'll learn something. I have personally NEVER had a cap come off on any vehicle I have own that had a distributor cap.
I could have sworn I have seen an extra hole or 2 in the bottom of a distributor housing, the alum chrysler single point anyway ???
Re: Distributor Cap Blow off [Re: 62maxwgn] #983781
05/02/11 01:35 PM
05/02/11 01:35 PM
scratchnfotraction Offline
caps have vents to let positive charged ions out,when they build up inside the cap it can cause carbon tracking and mis-fires.
used to see it on roundy round dirt track cars,mostly with the chebby HEI dizzys and big fat caps.
dont think it blows the cap off though
Re: Distributor Cap Blow off [Re: scratchnfotraction] #983782
05/02/11 01:48 PM
05/02/11 01:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
dont think it blows the cap of though
I can see that . Reason you don't see it blow the cap of an HEI I guess would be because it is bolted down ?
Re: Distributor Cap Blow off [Re: JohnRR] #983783
05/02/11 02:08 PM
05/02/11 02:08 PM
now I know why chebby used screws on the cap.
I had a 69 440 4-v 4-speed RR blow the cap off 1x.i was running in 4th at 4800-5000 rpms,let all the way off the throttle real fast and bang...blew out a muffler,had the coil wire out of the cap and cap cocked side ways with 1 clip still holding it.
never did it again,and I have no idea why it did it that time either,but it sure skeeerd me when it went bang!
dont think it had anything to do with the dizzy and cap.
Page 1 of 3 1 2 3
