Re: ' PAGING PATRICK ' RE; MAGNUM HEADS
[Re: Dennispsalm91]
#98298
08/01/08 06:44 PM
08/01/08 06:44 PM
Posts: 12,478 Kalispell Mt.
HotRodDave
Kalispell Mt.
Lots of peopole here could help, Patrick is a good one.
Can I ask, What are your questions?
[Re: Dennispsalm91]
#98300
08/01/08 07:58 PM
08/01/08 07:58 PM
HotRodDave
Kalispell Mt.
340s did not come with magnum heads, only 318s and 360s cam with them. They came out in 1992-2002, 340s were made from 68-73. Specs for them I can think of off the top of my head are 65cc chambers flow about 215cfm OOTB can flow about 270 full ported and 2.02 valves. They come from the factory with 1.94 IN and 1.65 EX valves and full ported with them can flow 260. Valve lengths are about 4.9 inches. Valve stems are 8mm instead of the 340s .375 stem diameter, this helps flow and reduces valve weight. They do not have the heat crossover passages. They use a 10 bolt valve cover but the old 5 bolt covers have holes in the sam places and some guys say they use them with no problems. Advertised Rocker ratios are 1.6 on the magnum and 1.5 on the 340. In actuallity most 340 rockers are more like 1.45 and magnum rockers closer to 1.65 so with the same cam you get more lift . They will swap from the later motors to the 340s and are a very good swap. To do the swap you will need new pistons if it is a 68-71 340 72-73 340 pistons are fine. (a note on the early pistons, if you have some really thick head gaskets you might not have to swap pistons, it depends on the exact deck height of your block and how thick of gaskets you get) You will need lifters with pushrod oiling holes, 99% have them but check to make sure yours do, it is a small hole in the bottom of were the pushrod goes in the lifter. You will need different pushrods because the length is different and they need to be hollow so oil can flow through them. You will need magnum style rockers and bolts. The intake will need to be swaped OR drill and tap the 340 style intake bolt holes into the magnum heads. If you need specific specs I have several books I can look in here at my house. Hopefully Patrick will chime in soon, where is he
[Re: Dennispsalm91]
#98302
08/02/08 05:28 PM
08/02/08 05:28 PM
RapidRobert
you're getting everyone but patrick & I was the "member" that suggested you page him! I sure hope when he does arrive that he has some good info to share. He will.
[Re: Dennispsalm91]
#98305
08/02/08 07:22 PM
08/02/08 07:22 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
The heads will bolt on,but use different head bolts. As long as the pistons haven't been replaced with a dome piston they will work,but check your piston to deck clearance to confirm this.Lifters need to oil thru the pushrods,most MP lifters won't do this. Look at them,do they have a hole in the pushrod cup? Most companys carry a lifter that will work,so thats not a problem. You won't be able to use the LA pushrods,but they are easy to replace.You will need to redrill the heads to use an LA intake or you'll be limited with intake choices. I like to tap the oil passages on the decks surface to shut of the oil to the LA valvetrain but others have had no problem allowing the magnum heads lack of this passage block the oil passage. What have I forgotten?
[Re: Dennispsalm91]
#98307
08/02/08 08:31 PM
08/02/08 08:31 PM
goldmember
Gainesville,FL
I redrilled the heads,there was at one time a jig built to help,but it's not a must have to do this. Modifying the intake doesn't look too appealing althought it can be done.Compression will increase about 1/2 point.
[Re: tpabayflyer]
#98309
08/03/08 11:21 AM
08/03/08 11:21 AM
RapidRobert
TBF could you give me guesstimate with your experience on this on how many CC's I could add by trimming the eyebrow & unshrouding the valves(& anything else) in the chamber shown? I have magnums in a project coming together & my CR is too high & I don't want to ch my pistons. thank you for your time Bro. PS Patrick is deceased.
[Re: GO_Fish]
#98312
08/03/08 12:49 PM
08/03/08 12:49 PM
RapidRobert
Dead & gone. I'm not exactly sure what happened.
[Re: JDMopar]
#98314
08/03/08 03:58 PM
08/03/08 03:58 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
uh, no, I'm still here. been a busy weekend
are the pistons above or below deck? if above deck, you'll need to measure how much, and look for a head gasket that is .040 thicker than that measurement (say, if they're .018" above deck, you'll want to look for head gaskets that are ~.060 thick).
baby's crying, I'll write mroe later....
[Re: RapidRobert]
#98315
08/03/08 05:04 PM
08/03/08 05:04 PM
HotRodDave
Kalispell Mt.
Whew! Glad your alive Patrick!
would be hard to remove more than 2 or 3 CC without ruining the chamber. You could mabey put in tuliped valves 2.02 diameter and run a deshroud cut out to the edge of the bore. You could probably take another cc out by removeing the second quench pad but I hate removing quench area, it helps resist detonation.
[Re: patrick]
#98316
08/03/08 05:21 PM
08/03/08 05:21 PM
Posts: 4,204 Fort Worth, TX
Clair_Davis
Fort Worth, TX
Samuel L. Clemens, speaking for Patrick 111 years ago:
"The report of my death was an exaggeration"
This explains it all. Nothing like having a monkey (or two) for making days go by in about 30 minutes and making parents seem to disappear...
Glad to have you "back", Patrick!
Clair (with 2 monkeys in the house)
