Re: 727 Overheats! [Re: modelmakerinc] #982455
04/29/11 08:47 PM
04/29/11 08:47 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
Make sure the lower cooler line is the feed. If you run it thru the cooler top down it may not cool correctly.Do you have acsee to an infared heat gun? You could use it to check the temps.
Re: 727 Overheats! [Re: fox] #982456
04/29/11 09:31 PM
04/29/11 09:31 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Really? Doesn't the pump push fluid through the cooler at same rate regardless of line orientation?
Re: 727 Overheats! [Re: fox] #982457
04/29/11 10:24 PM
04/29/11 10:24 PM
Clinton Twp. Michigan
coronet1966d Offline OP
well its cooked! i think its the pump or the planetary gears making a ton of noise
Re: 727 Overheats! [Re: coronet1966d] #982458
04/30/11 12:19 AM
04/30/11 12:19 AM
MINNESOTA
BRONZEBEE Offline
BRONZEBEE  Offline
MINNESOTA
If your running road gears 2.76 3.23,with a 3200 stall might give you a problem.I think it will overheat the fluid in the converter,because the stall is to high for the gear ratio.Example 55 mph 2200 rpm,3200 stall.Your stall speed should be below your crusing rpm.
Re: 727 Overheats! [Re: BRONZEBEE] #982459
04/30/11 02:06 AM
04/30/11 02:06 AM
im running 4.10 gears
Re: 727 Overheats! [Re: coronet1966d] #982460
04/30/11 09:04 AM
04/30/11 09:04 AM
west palm beach, florida
modelmakerinc Offline
Well something in the story is missing. You said the tranny was leaking bad after cruising. If you read my reply then you know the valve body causes this problem (somehow). Now you say that it sounds like it is severely broken, that doesn't happen from overheating. Did you romp on it in first and let off hit it again, if your valve body doesn't have low band apply then that is what probably broke the internals and be happy that it didn't come apart entirely :-(
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: 727 Overheats! [Re: coronet1966d] #982461
04/30/11 07:07 PM
04/30/11 07:07 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Call me if you need help pulling it John. I've got the 5A all tore apart right now in the middle of a 518 swap.
Re: 727 Overheats! [Re: coronet1966d] #982462
05/01/11 03:41 AM
05/01/11 03:41 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I had a torque converter with a crack in the hub where it goes into the pump and it leaked pretty bad, but that was a 904 transmission?
I like the vent relocation to the rear of the transmission too.
Re: 727 Overheats! [Re: 451Mopar] #982463
05/02/11 11:02 PM
05/02/11 11:02 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
x2
Re: 727 Overheats! [Re: MarkZ] #982464
05/03/11 01:16 AM
05/03/11 01:16 AM
ive been trying to get ahold of you, i dont think i have your number
