sb head studs #982332
04/28/11 11:08 PM
04/28/11 11:08 PM
NC
barracuda man Offline OP
NC
need a part# for head studs with 12 point nut for sb 340 with edelbrock heads.
Re: sb head studs [Re: barracuda man] #982333
05/04/11 04:55 PM
05/04/11 04:55 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Re: sb head studs [Re: barracuda man] #982334
05/04/11 05:33 PM
05/04/11 05:33 PM
Guitar Jones Offline
Just call ARP, Summit, Jegs, etc.
"Come get your wife"
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion.
Re: sb head studs [Re: barracuda man] #982335
05/04/11 11:09 PM
05/04/11 11:09 PM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
not 12 point but these are the ones we used for our 340 with Edelbrock heads and fit fine for us.
Re: sb head studs [Re: barracuda man] #982336
05/04/11 11:11 PM
05/04/11 11:11 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
144-4005 EDDY HEAD STUDS
http://www.summitracing.com/parts/ARP-144-4005/
EDIT - sorry they are 6 point...
Re: sb head studs [Re: DJVCuda] #982337
05/04/11 11:20 PM
05/04/11 11:20 PM
Renton Washington
Triple Threat Offline
Renton Washington
Kinda off topic, what head studs/ bolts do Indys use?
Stock? W2? Eddy? W5?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: sb head studs [Re: DJVCuda] #982338
05/04/11 11:20 PM
05/04/11 11:20 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
You need that stud kit then have to buy seperate packages of 12 point nuts. They dont make the kit for them with 12 points included.
RIP Monte Smith
