Re: ideling in ear problem
[Re: mopfried]
#982300
04/28/11 10:59 PM
04/28/11 10:59 PM
dartman366
Mt. Vernon, Ohio
couple of thing's,,initial timing, are you using a mechanical advance or just not using the vac diaphragm, also if that all check's out then you might want to switch to a smaller air bleed in the idle circuit to richen it up a little.
[Re: mopfried]
#982302
04/28/11 11:52 PM
04/28/11 11:52 PM
Posts: 394 md
wicked
md
I think you hit it when you said converter is tight.
[Re: Dunnuck Racing]
#982305
04/29/11 09:37 AM
04/29/11 09:37 AM
Posts: 1,322 Michigan
crlush
Sounds like you may need more initial timing.Try putting a couple more degrees in it and see if it improves,if so you might need to limit the mechanical advance and crank up the initial timing. Keith
what he said
Re: idleing in gear problem
[Re: mopfried]
#982306
04/29/11 09:44 AM
04/29/11 09:44 AM
Posts: 531 Virginia
JimG
Virginia
If I raise the float level really high (did by mistake) it seems to help.
Besides what's already been suggested, check the relationship between the throttle plates and the transition slot at idle. The fact that raising the float level improved the situation leads me there.
No more than a "square" of t-slot should be exposed at idle. Much more, and you run the risk of partially idling on the main circuit, which is far more sensitive to float level.
As previously stated, ithe IABs are on the outside. If that 750 doesn't have screw-in air bleeds, you can partially block them with a small piece of wire, just for a test. Check the blade/t-slot relationship before you do that, though. And if you're still thinking you need more initial timing, do that before you do anything to the carb.
[Re: mopfried]
#982308
04/29/11 10:14 AM
04/29/11 10:14 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Thanks. I will bump the timing and if that dont do it I will check the slots. I dont think the cam is big enought to need a looser convertor.
Yes your right, that cam is mild & should be fine with a 2-2200 stall, Play with the timing 1st., make sure all the ignition is in good shape too, & check for any vacuum leaks.
Re: ideling in gear problem
[Re: mopfried]
#982315
05/02/11 11:44 PM
05/02/11 11:44 PM
joedust451
super gas
super gas
Branson, Mo.
I have advanced the timing all over the place, retuned the carb idle screws and idle speed. I think its too rich. it seemed better when the engine was cool. I can plug one of the primary idle bleeds an it slowes down, plug both of the and it almost dies. As far as the transfer slots go I had the timing up high enough the idle screw was barely turned. i backed off the secondary idke screw until it was shut.... nothing seems to help. The converter is tight. idle at 1000 1100 and it drops into gear hard.
Make sure the IABs are not stopped up, spray all 8 with carb cleaner, check the plugs & make sure they are not foiled at this point, i'll bet they are, You will play "hell" trying to get it tuned if they are , install a fresh set, then play with the timing, I still say that cam is mild, tuned in, it should hold around 12 in. of vacuum, we ran one in a mild 360 with a stock type converter & 3.91 gears, the RPM would only drop around 300, the torque was outstanding & it was a tire fryer, If all else fails, you may need to open up the primary IABs around .003", if you need any more help, feel free to PM me.
[Re: mopfried]
#982317
05/04/11 10:04 AM
05/04/11 10:04 AM
joedust451
super gas
super gas
Branson, Mo.
I tried cleaning the idle bleeds and no help so I pulled the carb and checked the idle slots. They looked OK. I found the secondary shaft pretty loose. Probably enought to cause a vacuum leak. I had checked that with carb cleaner but it didnt show bad. My thought was to compare idle passages in the meteing block to another. Since the shaft was so loose I just put the BG 850 DP back on. It dosent seem to run as rich but still stalls when I drop it in gear... I have a Mallory unilite dist.... I put it in and guess what, the stalling quit? I dont understand. I know the total timing is way high. I will fix that tonight. Thank God for start retard!
Sounds like your just having a timing problem, you don't have enough int. timing, Is that Mallory adj., if so, i'd be setting it up around 16* int., 36* total all in around 24-2600. Once you get the bugs worked out you'll see i'm right about that cam, it will idle with a very mild converter.
