NE1 still modding 5.7 harnesses for E body? #980284
04/25/11 03:15 PM
04/25/11 03:15 PM
Tucson AZ
2
2cudabuck Offline OP
Tucson AZ
Good morning everyone, hope all had a great Easter weekend! I have sent a couple of PM's to people who had said they would take your stock 5.7 harness and trim it down for the swap, but have had no replys. Do any of you know if anyone on the list is doing it? I have EVERY peice from my donor truck and it seems ashame (not to mention $1K) to not be able to use the stock harness. Thanks all, I look forward to hearing from you all!!
Buck
Buck 67 273 Dart GT 69 RT 440 Charger (SWEET!) 70 318 Cuda 74 Cuda Packin a 426 roller Hemi
Re: NE1 still modding 5.7 harnesses for E body? [Re: 2cudabuck] #980285
04/25/11 04:02 PM
04/25/11 04:02 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Why not do it yourself ?
Just get a factory service manual for the vehicle the engine/harness is out of and go wire by wire and either keep or get rid of what you don't need.
That is just what I did on my LS1/Torana swap and it works great without buying an aftermarket loom.
Re: NE1 still modding 5.7 harnesses for E body? [Re: OzHemi] #980286
04/25/11 04:36 PM
04/25/11 04:36 PM
Tucson AZ
2
Tucson AZ
I'm pretty handy and that wouldn't scare me off, but I just don't have the knowledge of what the motor needs to run and what it doesn't! Like all four o2 sensors, (does it need all four?) and various other systems and sensors. There aren't that many unattached wires right now, so I would be willing to go for it if I new what was needed!! Hmmm, thanks for the possiblity, I'm pondering it...
Re: NE1 still modding 5.7 harnesses for E body? [Re: 2cudabuck] #980287
04/25/11 06:44 PM
04/25/11 06:44 PM
Tucson AZ
2
Tucson AZ
BUMP!!!
Re: NE1 still modding 5.7 harnesses for E body? [Re: 2cudabuck] #980288
04/25/11 08:23 PM
04/25/11 08:23 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I'm not sure on the O2 sensor thing with the Hemi's, hopefully someone can chime in on that, or perhaps check with a company that flashes the PCM's for them about what you can or can not get rid of ?
(Or maybe try and get a close look of an aftermarket loom to see what they are using)
On mine, I had a pretty good idea of what could stay and what could go... I ditched the rear O2's, the EGR stuff , etc. Also adjusted the length of certain parts of the harness at the same time to suit where I was going to run the PCM.
Here was mine in process..
Re: NE1 still modding 5.7 harnesses for E body? [Re: OzHemi] #980289
04/25/11 11:24 PM
04/25/11 11:24 PM
Tucson AZ
2
Tucson AZ
ZOINKS!!! I think I would need a real good "roadmap" of what to keep and eliminate to tackle that myself after seeing that! I'm getting the dealership to run all my numbers and stuff tomorrow so I can see the extent of my reflash. Other than that, a fuel pump and regulator and I'm ready to go!! Any more input folks, I'm lovin it!
Re: NE1 still modding 5.7 harnesses for E body? [Re: 2cudabuck] #980290
04/25/11 11:45 PM
04/25/11 11:45 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
The factory service manuals did the job for me.
Re: NE1 still modding 5.7 harnesses for E body? [Re: OzHemi] #980291
04/26/11 01:44 PM
04/26/11 01:44 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
i did my truck harness myself. Personally, they are tedious to do the 5.7 engine harness, to be able to make any money at it (at least for me). An 04 ram service manual has a master wiring diagram that worked perfect for me. I would be glad to answer questions, but just dont have the time do it.
It is doable though, just time consuming.
Justin
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: NE1 still modding 5.7 harnesses for E body? [Re: wldtm] #980292
04/26/11 07:11 PM
04/26/11 07:11 PM
Tucson AZ
2
Tucson AZ
how do you all know what sensors and stuff the engine is going to require to run right and the repurcussions of removing things? My motor and trans came from an 05 2wd Ram, and I have EVERYTHING from the harness, down to the bulbs.
Re: NE1 still modding 5.7 harnesses for E body? [Re: 2cudabuck] #980293
04/26/11 10:56 PM
04/26/11 10:56 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
basically if you use the 04-05 master engine system wiring diagram you use all the sensors listed. Sensors = upstream 02 sensoer, cam, crank, app, Elec Throttle Control motor, knock. Relays = asd relay, starter relay, fuel pump relay. These are some necessary ones. Might be a few more, but these are essential.
Try to find an 04 ram manual, it should be the same as 05. You need to have an idea where to start. Better yet email me at wldtm@hotmail.com I will try to see if I can send you the wiring diagram.
I did not use the auto trans from the truck in mine.
