Re: MIXING OCTANE GAS Does it work?
[Re: GRAYBO]
#979732
04/24/11 08:58 PM
04/24/11 08:58 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
If it runs well on pump gas,racing fuel mixed in is usually a waste.There are exceptions to this,such a higher rpm engines that can use the faster burning a real race fuel offers. If you are on the edge of detonation while cruising around and not racing,you might be better playing it safe with a mix though. Keith
[Re: GRAYBO]
#979734
04/24/11 09:06 PM
04/24/11 09:06 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I go through this debate every year. My motor is supposedly 12:1 or close to it. It runs perfectly fine on 93 octane on the street even with me pounding on it every now and then. But before I go to the track I go through the hassle of driving 20 minutes each way to put one gallon of 110 Cam2 in each jug for added security, it's a pain. My biggest fear is getting a batch of crappy pump gas and melting my motor, but I guess there could be a bad batch of race gas here and there. I think I'm perfectly fine on straight pump gas but afraid to try it at the track. I only have 150 cranking compression with my camshaft, also have aluminum heads and only run 36 total timing.
[Re: Dunnuck Racing]
#979735
04/24/11 09:21 PM
04/24/11 09:21 PM
Posts: 164 Harrisville,PA
GRAYBO
Harrisville,PA
Thanks to all. I guess.... Since last year I did pretty well with no problems mixing I should just stay with it..... Thanks guys. GRAYBO
[Re: GRAYBO]
#979737
04/24/11 10:19 PM
04/24/11 10:19 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
Last year I mixed 50% Turbo blue and 50% 93 pump gas. Is this a waste of time or does it help. My 440 engine is only 10.75-1 compression so it will run on pump gas without a problem. Thanks
YES! probably slow u down with that compression
[Re: ProSport]
#979738
04/24/11 10:22 PM
04/24/11 10:22 PM
fishy340
LONG ISLAND
your smart keep doin what u do,my cuda is fine on pump 93,but if im gonna bang it(1 gal of race to 4 pump)is worth not doin 8 g's worth of damage
[Re: fishy340]
#979739
04/24/11 10:27 PM
04/24/11 10:27 PM
ProSport
Akron, Ohio
It's a pain but definitely better than tearing up parts.
