Getting Power Out of a Slant Six
#979250
04/24/11 02:14 AM
04/24/11 02:14 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
What is the best way to get power out of a slant six? I know some turbo and few supercharge them. How much power can you get from rebuilding the engine with more performance mods. I am possibly thinking of building up my slant six instead of going through with a Gen III Hemi because it might be cheaper and the Dart would be more light weight. Any ideas. Something for street use that could still have fun in if I ever wanted to go autocrossing or some sort of racing. How difficult would it be to learn how to rebuild it yourself? Thank you for the advice. ![](/ubbthreads/images/graemlins/biggrin.gif)
Re: Getting Power Out of a Slant Six
[Re: MuuMuu101]
#979252
04/24/11 04:53 AM
04/24/11 04:53 AM
Posts: 2,006 s. e. pa.
calrobb2000
s. e. pa.
hi turbo it aint that hard to install . slants are beging to be turboed ! ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: calrobb2000]
#979254
04/24/11 01:11 PM
04/24/11 01:11 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I was thinking about turbos. I think the whole blow-through carb thing looks funky though. But then again, horsepower over looks. I am just thinking about it.
It is most likely going to be less $$$ than buying a Gen III HEMI and a new 5(or 6)-speed. I think just the engine and trans without any wiring and stuff is going to at least cost me $10k, then I have everything else to worry about. Would be a very cool Dart but would take forever just to get the money to build everything.
[Re: Supercuda]
#979257
04/24/11 03:43 PM
04/24/11 03:43 PM
Posts: 5,912 Athens, Greece
Pyper70
Athens, Greece
import a 265 Straight 6 from Australia....The Hemi 6...and blow away the competition with that little monster.
I have put $1500 into the head along on a 225...500cfm Edelbrock, Aluminum Offy 4bbl...Tri-Y headers....if I could do it all over again....I would try to stuff a 265 under the hood
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#979258
04/24/11 05:03 PM
04/24/11 05:03 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I already asked OzHemi about it. The problem is the 265 is 3-4 inches too long so I would either have to move the firewall back or get a Ozzie Front clip (which is much longer). Not only that but the 6 pack carburetors interfere with the master cylinder location.
[Re: MuuMuu101]
#979259
04/24/11 05:44 PM
04/24/11 05:44 PM
Pyper70
Athens, Greece
Where theres a will theres a way....You can always move the radiator support further forward, remove the mechanical fan, and run 2 pushers from the front. If you mill some 90º aluminum bodies you can probably set the 6-pack carbs in a vertical orientation or find some motorcycle carbs that will fit...It would take some research but it would come out fine I am sure. I had my six all dolled up and I was taking out small blocks with it. Daily driver. about 22mpg with attitude. My next upgrade for it was a Turbo setup but I moved and couldnt take three cars where I was going.
[Re: Pyper70]
#979261
04/24/11 05:57 PM
04/24/11 05:57 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Yeah, I forgot about moving the radiator support forward, the only thing is that it may be too nose heavy then, and I really don't want to modify the engine bay too much just in case I want to do a Gen III HEMI swap later on in life. I just want a temporary drivetrain I can still enjoy taking to muscle car gatherings and cruise in as I go.
I actually do have an all stock 318 from a 70 or 71 Barracuda but the only thing is that it is going to need a rebuild. I was thinking about doing something with that later on in life. Maybe something different like having a Blower on it.
I like things that are unique and that most people due. It would be pretty cool to adapt a supercharger to the slant-six. Kind of like these guys:
http://www.youtube.com/watch?v=hzqzJptexW8
http://www.youtube.com/watch?v=iSIsCAGV7A0
[Re: MuuMuu101]
#979262
04/24/11 08:22 PM
04/24/11 08:22 PM
Pyper70
Athens, Greece
The way gas is going....is adding a supercharger really gonna be wallet friendly...You are adding more air...when you add more air you need to add more fuel...The videos are definitely cool though...
[Re: Pyper70]
#979263
04/25/11 12:45 AM
04/25/11 12:45 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
It's not going to be a daily driver, just a cruiser and something I can take to the car gatherings. Idk, I am just circulating through some ideas. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: MuuMuu101]
#979264
04/25/11 01:52 AM
04/25/11 01:52 AM
Posts: 550 SW Missouri
moparmandjh
SW Missouri
I'm gonna put this on my /6 Dart sport. Yes I know blow thru is better but I am doing it with ZERO budget. Doc
American soldiers in battle don't fight for what some president says on tv, they don't fight for mom, apple pie, or the American flag... they fight for one another. -Lt. General Hal Moore
[Re: DaytonaTurbo]
#979266
04/25/11 02:17 AM
04/25/11 02:17 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Find a junkyard magnum 360. Have the heads cleaned and checked out. New valve springs, have the stock roller cam reground. Edelbrock intake for magnum heads, headers, and a backyard hone'n're-ring with cast piston rings, new timing chain/gear set and a hv oil pump with a bigger pan/pickup. Will make good power and you won't have to reinvent the wheel. You would be going with a well documented, proven performance combo. In the end would be much easier than doing any serious mods to your slant IMO because of the serious lack of custom engineering/fabrication required.
Approximately how much would this cost??? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: DaytonaTurbo]
#979268
04/25/11 10:37 AM
04/25/11 10:37 AM
Posts: 3,152 Central NC
gch
Central NC
Old school hot rod approach always works.Have someone (who knows slant 6's)port the head,better compression,solid cam,4bbl intake and a header.It would be fun to see what you can get out of it. If it is a stick all the better. Can you stroke a slant 6? ![](/ubbthreads/images/graemlins/image_294343.gif)
[Re: gch]
#979269
04/25/11 01:13 PM
04/25/11 01:13 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
A 225 is almost as heavy as a SB and about the same as a gen III hemi so handling is not gonna be much different. Bone stock even a 5.7 hemi is gonna make 3 or 4 times the power of a slant.
As for makeing a stroker slant, how much more are you thinking you will gain? It comes with a 3.4 bore and 4.125 stroke, very high stoke to bore ratio and with small bores and valves you are likely to only gain a few pounds of TQ and no HP, the same could be acomplished easier by switching rear end ratios.
