Re: Do you change oil before storage or after?
[Re: MoparforLife]
#978724
04/23/11 10:21 AM
04/23/11 10:21 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I would do it before--oil won't go bad sitting in an oil pan all winter. and it gets rid of exhaust contaminated oil.
worst that will happen is you get some moisture/condensation build up over the freeze and thaw of winter, but the first time you drive it and get everything good and hot, that moisture will evaporate out.
**Photobucket sucks**
[Re: Dr Lebaron]
#978727
04/23/11 11:26 AM
04/23/11 11:26 AM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
I think that we will all agree that MOST GUYS here ....on anything we drive ....we have fairly fresh oil in even our daily-drivers. So as long as the oil is "clear" and relatively fresh(the last two motors I shut-down - a 440 and 413)...not to worry. Both had a 1000 or so miles on the oil-change. It is just a personal preference though. I have heard of some that change oil before and after coming out of storage .... Oh well .. it is their money to spend as they see fit.
[Re: dOc !]
#978728
04/23/11 01:07 PM
04/23/11 01:07 PM
Posts: 21,814 Kirkland, Washington
Pacnorthcuda
I agree. Unless the oil is really due for a change (pick your number, I would pick around 4000 miles) I wouldn't sweat it too much.
That said, Doc---you pick some really twisted avatars at times.
[Re: dOc !]
#978731
04/23/11 01:25 PM
04/23/11 01:25 PM
Pacnorthcuda
Is THIS ONE bester ?
Yea...I think so. Makes me wonder what you have tied-up in the basement.
[Re: gd9704]
#978733
04/24/11 10:37 AM
04/24/11 10:37 AM
Posts: 4,323 NY NY
340duster340
NY NY
it's good to see that someone else is also still wearing jorts (cut jean shorts)
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
[Re: 340duster340]
#978734
04/24/11 12:28 PM
04/24/11 12:28 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
The Aeroshell engineer give a greal good seminar on oils, the guys above are correct about getting out the oil with the acids in it. Shell actuall makes a pickling oil to preserve an engine at the end of the season. But what they may not know is that the oil needs to be changed probably very soon after the can/jug has been opened. He recommends that at 6 months whether its been ran or not it needs to be changed because the oil will absorb moisture and start to form acids again. This will cause corrision. Most people dont know that oil also has a 4 year shelf life. This is due to the additives that are put into the oil begin falling out of suspension. They CANNOT be reinstalled by warming the oil up either. When they add the additives, they begin by heating the base oil and start adding each chemical at a specific temperature, at like somewhere near 350, they are finished. The use by date is marked on the case, not on each jug. Just a little trivia. Tim
[Re: astjp2]
#978737
04/24/11 05:41 PM
04/24/11 05:41 PM
dOc !
Florida STAYcation
I have never seen this data ....do you have an example ?
There have been PLENTY of oil-topics on-here and I have NEVER seen someone mention any type of automotive lubrication product having an expiration-date.
[Re: astjp2]
#978738
04/24/11 11:37 PM
04/24/11 11:37 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
Good points!
The shelf life of motor oil varies somewhat per manufacturer, but it's somewhere between 3-to-5 years given the oil is properly stored. For example: Store lubricants in a cool, clean, and dry indoor area with an ideal storage temperature of between 45ºF and 80ºF.
Also good notes on how additives are properly blended into the oil by the manufacture. This is why it's not a good idea to dump aftermarket motor oil additives into your crankcase and why no auto manufacturer condones the use of aftermarket motor oil additives.
