Do you change oil before storage or after? #978722
04/23/11 09:27 AM
04/23/11 09:27 AM
MN
Skid_Demon Offline OP
MN
Living in the frozen north, the old Chrysler is put to bed for the winter Oct/Nov. Going to fire it up today. Do you change the oil just before storage , or wait and add that task to the spring list? I have talked to guys at car shows and have heard good reasons for both. I don't want to change just before storage and again in spring, so what's your opinion?
Re: Do you change oil before storage or after? [Re: Skid_Demon] #978723
04/23/11 09:41 AM
04/23/11 09:41 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Before. Don't want to store it with the built up acids and contaminants in the oil.
Re: Do you change oil before storage or after? [Re: MoparforLife] #978724
04/23/11 10:21 AM
04/23/11 10:21 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I would do it before--oil won't go bad sitting in an oil pan all winter. and it gets rid of exhaust contaminated oil.
worst that will happen is you get some moisture/condensation build up over the freeze and thaw of winter, but the first time you drive it and get everything good and hot, that moisture will evaporate out.
**Photobucket sucks**
Re: Do you change oil before storage or after? [Re: 70Cuda383] #978725
04/23/11 10:38 AM
04/23/11 10:38 AM
Willoughby Hills, Ohio
gd9704 Offline
super gas
gd9704  Offline
super gas
What these guys said!
Re: Do you change oil before storage or after? [Re: MoparforLife] #978726
04/23/11 11:05 AM
04/23/11 11:05 AM
Frozen Wastelands, Ontario, Ca...
Dr Lebaron Offline
Dr Lebaron  Offline
I've always done a oil change/filter like 10 minutes before I store it. Then I change the oil at about 1/2 the mileage in spring.
Re: Do you change oil before storage or after? [Re: Dr Lebaron] #978727
04/23/11 11:26 AM
04/23/11 11:26 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I think that we will all agree that MOST GUYS here ....on anything we drive ....we have fairly fresh oil in even our daily-drivers. So as long as the oil is "clear" and relatively fresh(the last two motors I shut-down - a 440 and 413)...not to worry. Both had a 1000 or so miles on the oil-change.
It is just a personal preference though. I have heard of some that change oil before and after coming out of storage ....
Oh well .. it is their money to spend as they see fit.
Re: Do you change oil before storage or after? [Re: dOc !] #978728
04/23/11 01:07 PM
04/23/11 01:07 PM
Kirkland, Washington
Pacnorthcuda Offline
I agree. Unless the oil is really due for a change (pick your number, I would pick around 4000 miles) I wouldn't sweat it too much.
That said, Doc---you pick some really twisted avatars at times.
Re: Do you change oil before storage or after? [Re: Pacnorthcuda] #978729
04/23/11 01:20 PM
04/23/11 01:20 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Why THANKS PacMAN ...... you are mildly TWISTED yurrself !
...an admirable trait ... indeed !
Re: Do you change oil before storage or after? [Re: dOc !] #978730
04/23/11 01:23 PM
04/23/11 01:23 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Is THIS ONE bester ?
Re: Do you change oil before storage or after? [Re: dOc !] #978731
04/23/11 01:25 PM
04/23/11 01:25 PM
Yea...I think so. Makes me wonder what you have tied-up in the basement.
Re: Do you change oil before storage or after? [Re: Pacnorthcuda] #978732
04/23/11 01:31 PM
04/23/11 01:31 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
TIED UP ? ...in the basement ? ? ..... that happened in the hot-tub room ... Yeah - she liked being that ...
Re: Do you change oil before storage or after? [Re: gd9704] #978733
04/24/11 10:37 AM
04/24/11 10:37 AM
NY NY
3
340duster340 Offline
NY NY
it's good to see that someone else is also still wearing jorts (cut jean shorts)
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: Do you change oil before storage or after? [Re: 340duster340] #978734
04/24/11 12:28 PM
04/24/11 12:28 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
The Aeroshell engineer give a greal good seminar on oils, the guys above are correct about getting out the oil with the acids in it. Shell actuall makes a pickling oil to preserve an engine at the end of the season. But what they may not know is that the oil needs to be changed probably very soon after the can/jug has been opened. He recommends that at 6 months whether its been ran or not it needs to be changed because the oil will absorb moisture and start to form acids again. This will cause corrision.
Most people dont know that oil also has a 4 year shelf life. This is due to the additives that are put into the oil begin falling out of suspension. They CANNOT be reinstalled by warming the oil up either. When they add the additives, they begin by heating the base oil and start adding each chemical at a specific temperature, at like somewhere near 350, they are finished. The use by date is marked on the case, not on each jug.
Just a little trivia. Tim
Re: Do you change oil before storage or after? [Re: astjp2] #978735
04/24/11 12:36 PM
04/24/11 12:36 PM
the guys above are correct about getting out the oil with the acids in it. He recommends that at 6 months whether its been ran or not it needs to be changed because the oil will absorb moisture and start to form acids again. This The use by date is marked on the case, not on each jug.
good stuff
Re: Do you change oil before storage or after? [Re: RapidRobert] #978736
04/24/11 01:00 PM
04/24/11 01:00 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I missed a few things, the shelf life is 4 years on a case of oil, and if you run your engine during its down time, you need to get the oil temp to above 150 for an hour to get the moisture out. My bad. I need to read my post before posting ...Tim
Re: Do you change oil before storage or after? [Re: astjp2] #978737
04/24/11 05:41 PM
04/24/11 05:41 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
I have never seen this data ....do you have an example ?
There have been PLENTY of oil-topics on-here and I have NEVER seen someone mention any type of automotive lubrication product having an expiration-date.
Re: Do you change oil before storage or after? [Re: astjp2] #978738
04/24/11 11:37 PM
04/24/11 11:37 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Good points!
The shelf life of motor oil varies somewhat per manufacturer, but it's somewhere between 3-to-5 years given the oil is properly stored. For example: Store lubricants in a cool, clean, and dry indoor area with an ideal storage temperature of between 45ºF and 80ºF.
Also good notes on how additives are properly blended into the oil by the manufacture. This is why it's not a good idea to dump aftermarket motor oil additives into your crankcase and why no auto manufacturer condones the use of aftermarket motor oil additives.
