What is this Hose Clamp (440-6 motor)? #97824
07/31/08 07:07 PM
07/31/08 07:07 PM
USA
stan1970 Offline OP
stan1970  Offline OP
USA
Hey Guys,
I have this odd looking hose clamp on the PCV hose from my center six-pack carb to the valve cover.
I've never seen a clamp like this before. Was this a Mopar-issued type clamp? Or did they use those standard ring-type clamps on the PCV hoses from the carbs (or no clamps)?
Also, I don't want to break this clamp off if it's an original style -- anyone know how they are properly released?
Thanks !
Re: What is this Hose Clamp (440-6 motor)? [Re: stan1970] #97825
07/31/08 07:29 PM
07/31/08 07:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's called a Keystone clamp, they have to be cut to remove them. The installation tool looks like a large end cutter.
Re: What is this Hose Clamp (440-6 motor)? [Re: John_Kunkel] #97826
07/31/08 07:40 PM
07/31/08 07:40 PM
USA
stan1970 Offline OP
stan1970  Offline OP
USA
Thanks much John.
I need to remove this hose as I'm going to be taking off the carb ... I guess I'll just cut this clamp off and use a regular hose clamp in it's place. I learn something new in every post here.. !
Re: What is this Hose Clamp (440-6 motor)? [Re: stan1970] #97827
07/31/08 08:04 PM
07/31/08 08:04 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
I removed a clamp similar to that once by bending the clamp with a screwdriver. After reinstalling the hose, I recrimped it with cutters. Can't recall what it was on, maybe a PVC system. But it did not matter if it was a perfectly tight seal.
Re: What is this Hose Clamp (440-6 motor)? [Re: QuickDodge] #97828
07/31/08 08:10 PM
07/31/08 08:10 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Ditto, stick a small screwdriver in there and give it a twist both directions...That'll loosen it up enough to get that peticular connection apart...One word of advice though...If you're going to be digging in there tuning the set-up just get a newer "corbin" clamp so you can get it off easily with a plyers... Take your hose along to the local NAPA store and they'll match the correct size for you..
Re: What is this Hose Clamp (440-6 motor)? [Re: screamindriver] #97829
07/31/08 08:19 PM
07/31/08 08:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Reusable.
Re: What is this Hose Clamp (440-6 motor)? [Re: stumpy] #97830
07/31/08 08:36 PM
07/31/08 08:36 PM
USA
stan1970 Offline OP
stan1970  Offline OP
USA
Thanks a lot everyone ! Always a ton of help and ideas in this forum!!
