Re: Electric vacuum pump?
[Re: HR5058]
#977784
04/23/11 02:05 AM
04/23/11 02:05 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
I can do that, I think . What about the relief valve and one or both valve covers? Also, what tank do you use? Thanks Chuck
It doesn't pull enough vacuum for a relief valve. I never used one. I didn't even use a puke tank.
I had this breather in Valve Cover. Moroso # 68788
Chris.. ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Steve Reynolds]
#977787
04/23/11 11:59 AM
04/23/11 11:59 AM
Posts: 2,527 PA
moparacer
PA
Here is how I do it on alky.
I am concerned about moisture so I come out of each valve cover at the front, go into a breather tank that catches the moisture so I can drain it, then come out of it to the vacuum pump.
I don't think its a good idea to suck any oil and water through these pumps so that's why I put a catch can between the engine and pump.
Will post a pic of my setup after while.
Finishing it up right now.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: Keith Black®]
#977789
04/23/11 10:29 PM
04/23/11 10:29 PM
Posts: 2,527 PA
moparacer
PA
Ok here is how I rigged it up with my alky injection I just put on this past week. First pic shows out of the front of the valve covers and don't forget to make sure they are baffled or it will suck oil when the engine is running. Second pic is the breather setup I use to catch the moisture from the alky. I mounted the pump under the fender up front to save on space under the hood. The breather tube runs down through the hole where the battery tray was originally. As you can see the clear tubing is completely fogged up with moisture and water droplets with it running so its definatley pulling it out. Better off there then in the pan! Last pic is the pump under the fender. ![](http://i892.photobucket.com/albums/ac129/str8liner/evac%20setup/Evac3.jpg)
[Re: HR5058]
#977792
04/23/11 11:58 PM
04/23/11 11:58 PM
Posts: 2,527 PA
moparacer
PA
That red hose is the air outlet for the pump.
I just run it down along the frame to the lower control arm area.
If you are on gas or using it on the street it might not be a big deal where you run it to but I was concerned if it blew some moisture out on alky, where I ran it.
That tank is a moroso breather tank that I chopped up and modified into a catch can.
If you run on gas and had your valve covers baffled good you and didn't suck any oil into the pump you could go from the valve covers through the pump and put a breather tank on the outlet of the pump.
Moroso 85470 would work for that.
#977794
04/24/11 12:33 PM
04/24/11 12:33 PM
Posts: 2,527 PA
moparacer
PA
It should fix that.
Had a friend who had a 8 second Beretta and it had some oil seeps. He put on on it and it fixed it right up.
[Re: Eric]
#977796
05/01/11 06:43 PM
05/01/11 06:43 PM
Posts: 2,527 PA
moparacer
PA
I had an annoying pan gasket leak that would leak oil on the trailer floor between races. I had the header evac's on it the last 2 years. Ran the car with the electric pump on yesterday and checked this morning and the floor is dry as a bone! ![](/ubbthreads/images/graemlins/boogie.gif) Also, I came back from a pass yesterday and noticed that the dipstick was blown out, and oil had leaked from the valve cover gasket on the pass side. A further investigation found that the fuse holder that powers the vac pump lost contact and it wasn't running on that pass so yea, these things do make a difference! ![](/ubbthreads/images/graemlins/thumbs.gif)
