Page 3 of 3 1 2 3
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: GomangoCuda] #977422
04/28/11 12:32 PM
04/28/11 12:32 PM
DELAWARE
bee71mopar Offline
bee71mopar  Offline
DELAWARE
Ok so we have the numbers now.. Can I run my stock kickdown and throttle cable with a Performer RPM intake.I have a Weiand now and can't find the right setup.The car is a 71 Superbee 383 column auto.Any HELP would be appreciative.
I think the reason that Andyf started making the taller throttle cable brackets was because of the height of the Performer RPM intake.
You can get his brackets from several online venders.
You will find what you need about 3/4 of the way down this page.
http://www.arengineering.com/throttlebracket/Tbracket/tbracketframe.html
Thanks so I guess I will have to get the 3 or 4pcs. kickdown to make it work.
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: GomangoCuda] #977423
04/28/11 12:50 PM
04/28/11 12:50 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Looks like he only sells the bracket for the 3 piece kickdown rod
On my 71 Bee , factory used the 1 piece kickdown rod
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: bee71mopar] #977424
04/28/11 01:00 PM
04/28/11 01:00 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
You can make your 1 piece work on your 71 Bee
You just have to raise the bracket that attaches to the intake manifold - Get some aluminum or steel round stock that is hollow inside at your local hardware store for the intake bolts to slide through and watch the angle of the rod
I cant remember the exact measurement to cut the tubes - Wasnt much - Then paint them hemi orange
You should still have plenty of adjustment on the 1 piece slider for your kickdown linkage
Siberian Huskies
Re: Holley Street Dominator Vs. Edelbrock RPM [Re: bee1971] #977425
04/28/11 01:13 PM
04/28/11 01:13 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
You would be best to switch over to the Bouchilon cable setup with the RPM.
Page 3 of 3 1 2 3
