Re: are thermoquads any good
[Re: MoparforLife]
#975697
04/18/11 02:23 PM
04/18/11 02:23 PM
Posts: 30,632 Florida STAYcation
IcorkSOAK
Financed his waterbed
Florida STAYcation
If you can find one that the bowls aren't cracked or warped on they are fine.
THIS is the exception ...NOT the rule ..
6139 is a good piece..
[Re: bigblockbryan]
#975698
04/18/11 02:24 PM
04/18/11 02:24 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
Thats a 72 carb might work ok, but for your setup with that cam you cant beat a 750 dp
[Re: bigblockbryan]
#975700
04/18/11 03:01 PM
04/18/11 03:01 PM
Posts: 397 California, USA
Phil Saran
California, USA
Yes they will crack from over tighting. But a correctly setup TQ will run great.
Just look at the mopar stock eliminator cars that have to run them, if set up correctly they fly.
Phil Saran
Parker, Colorado
[Re: Mr.Yuck]
#975702
04/18/11 03:53 PM
04/18/11 03:53 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
If they work they're great. what's the rest of the combo? If that 484 cam isn't backed up by good compression, 3000+ stall and 3.91's I don't care what carb you put on it, it will be a DOG.
Don't forget the timing curve too. VERY important.
[Re: bigblockbryan]
#975703
04/18/11 03:59 PM
04/18/11 03:59 PM
joedust451
super gas
super gas
Branson, Mo.
okay i got a thermoquad on a 71 340 motor when i bought my demon it looks pretty good and suppose to work good anyway would this be a upgrade. Over my 750 eddy i have on top of my 440 the eddys stock in outta the box and my motor has some issues i think its due to my 484 cam lacking fuel im gonna also try a holley 750 dp my buddy runs on a camaro putting out 507 hp.
I would try your buddies 750dp, I'm sure you will like it, thats the carb i'd run on that combo, just make "damn" sure you have the timing curve set up right for that cam. Like mentioned earlier, at least a 3000 stall & 3.91s. If it were mine, I'd use a 36-3800 9.5" & 4.10s, 750dp.
Timing. 16-18* int., 34-36* total, all in by 22-2400 RPM.
[Re: ScottSmith_Harms]
#975709
04/19/11 10:29 AM
04/19/11 10:29 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
A 6139s Thermo-Quad is an excellent model and will work great on your car. This is one I recently restored for a fellow member.
looks good. How about 2 of them on a tunnel ram.....
#975710
04/19/11 11:53 AM
04/19/11 11:53 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Scott,these work well too!
