Anybody painting using Devilbiss HAR-602 air control? #975576
04/18/11 08:55 AM
04/18/11 08:55 AM
Vicksburg, MI
coffeeman383 Offline OP
Vicksburg, MI
I use one to remove water for sandblasting and it works fine, even in humid Michigan. Anybody using this as their sole means for removing water for painting in their garage? Should I go better $$$!!!? Recommendations? I'm on a low budget but atleast I have a budget
Re: Anybody painting using Devilbiss HAR-602 air control? [Re: coffeeman383] #975577
04/18/11 09:52 AM
04/18/11 09:52 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That it'll be fine, as long as the air is cool when it get's to the dryer so it can work. That small regulator seems to be not enough volume for sand blasting. imo Should be good for painting.
Re: Anybody painting using Devilbiss HAR-602 air control? [Re: coffeeman383] #975578
04/18/11 09:52 AM
04/18/11 09:52 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
where i work. they use sharpe water separators like the one in the pic.
i would recommend using just using a filter before the spray gun. they have paper similar to toilet paper inside them to catch water. i don't know the brand name we use at work. they are orange and have both male and female threads built into them that break easily. they are about $10 each at the paint store.
i found what we use on ebay.
http://cgi.ebay.com/Motor-Guard-Filter-A...=item19c4c12e49
perception is 90% of reality
