727 Neutral Safety Switch ? #975149
04/17/11 08:15 PM
04/17/11 08:15 PM
Illinois USA
justnuts40 Offline OP
Illinois USA
I have 727 trany. Im trying to get the NSS to work for the starter ground and the back up lights. Tell me if I'm wrong, but the two outside pins are the back up lights, 12 volts in and out, and the inside pin is the ground for the starter relay ground? I've checked the hot wire to the switch and have 12 volts. I've checked the center pin and have no ground out when in park, and nothing between the two outside pins in reverse. Bad switch?
Help1
Thanks for the post, Tony
etony58@gmail.com
Re: 727 Neutral Safety Switch ? [Re: justnuts40] #975150
04/17/11 09:28 PM
04/17/11 09:28 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
You are correct...Center is NSS and two outside terminals are back-up..But you have it backwards at the other end of the switch...Plastic plunger operates the NSS and the pin activates the back-up lights..I'd make sure the shifter linkage is properly adjusted first thing...
Re: 727 Neutral Safety Switch ? [Re: screamindriver] #975151
04/18/11 07:55 PM
04/18/11 07:55 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
sorry but this is incorrect the center metal pin on the inside is what grounds to the VB creating the ground that runs to the starter sol.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 727 Neutral Safety Switch ? [Re: screamindriver] #975152
04/19/11 03:33 PM
04/19/11 03:33 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The metal center pin serves both functions, it drops into a "divot" in the plastic shoe to activate the BU lights and in Neutral and Park it makes contact with the exposed metal base in the shoe to ground the starter relay.
The only reason the plastic plunger is spring-loaded is to keep it in contact with the plastic shoe.
Re: 727 Neutral Safety Switch ? [Re: John_Kunkel] #975153
04/19/11 03:49 PM
04/19/11 03:49 PM
Santa Fe,Texas
TexasMopar Offline
TexasMopar  Offline
Santa Fe,Texas
Thanks for the detailed operation of the switch and pic. Makes sense when you know the details. Jim
Re: 727 Neutral Safety Switch ? [Re: TexasMopar] #975154
04/19/11 04:31 PM
04/19/11 04:31 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
TECH ARCHIVE!!!
