Re: Recommendations on Carb Restoration
[Re: domingo]
#975048
04/18/11 04:21 PM
04/18/11 04:21 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Scott, how long can they sit after the rebuild before they are installed, just trying to know what kind of lead time I need so they dont go bad before installation/use.
They can sit for several years, no problem. I warrant any restoration work I do for as long as you own them, if a problem does occur on startup after storage you can rest assured, I will take car of it. To date I have had zero problems assosiated with customers using them after long term storage.
*Those aren't blasted Domingo, as bad as they appeared "before" they cleaned up rather easily in this case. Blasting is a LAST resort when a really nasty set is being restored, typically it's not required.
Regardless of the level of surface deterioration (or lack of such) the dichromate does leave a somewhat motled surface look, some dull and some reflective areas, photos exagerate the effect depending on the lighting.
As with anything being restored, the better the initial condition, the better the final results will be.
[Re: not_a_charger]
#975049
04/18/11 08:59 PM
04/18/11 08:59 PM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
Scott, I think he means that the captions for the "before" and "after" pix are reversed.
exactly
