Is my fuel pump dying? Mallory 140. #974823
04/17/11 09:25 AM
04/17/11 09:25 AM
west palm beach, florida
modelmakerinc Offline OP
On my way home from a show, my fuel pump started to vibrate and rattle the lines. Pretty significantly, I just filled the tank with 103 fuel from the track a couple weeks back. Does it sound like the pump has some internal damage? I have a large canister filter. Are these pumps rebuildable? Thanks in advance. Henry
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Is my fuel pump dying? Mallory 140. [Re: modelmakerinc] #974824
04/17/11 09:36 AM
04/17/11 09:36 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
maybe you should do a static flow test where you can hear what is going on and test the flow,flush the system in the same test.i never had a peoblem with my 140 that took me to mid 10,s/129.
Re: Is my fuel pump dying? Mallory 140. [Re: modelmakerinc] #974825
04/17/11 09:45 AM
04/17/11 09:45 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Do a flow test... with the noise... something changed...
could even be loose on the mounts
Re: Is my fuel pump dying? Mallory 140. [Re: MR_P_BODY] #974826
04/17/11 11:20 AM
04/17/11 11:20 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Could be cavitation... try it with a cool fuel system or check for a inlet restriction
Re: Is my fuel pump dying? Mallory 140. [Re: emarine01] #974827
04/17/11 12:32 PM
04/17/11 12:32 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
It's a pretty simple machine. Pull it apart, check the brushes in the motor, impeller in the pump, etc. FWIW, mine sounded different at idle than cruise.
Re: Is my fuel pump dying? Mallory 140. [Re: bobby66] #974828
04/17/11 01:24 PM
04/17/11 01:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That would be a voltage difference (most likely)
