Re: can we go over my 509 HYD combo? [Re: tboomer] #974296
04/17/11 05:29 PM
04/17/11 05:29 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
I have a set of crane irons that to be bushed Im trying to not spend the 350-600 bucks to get adjust rockers on the car. If i do that im going 557 cam!!!
74 dart sport 440 www.Csucarbs.com
Re: can we go over my 509 HYD combo? [Re: shoebox] #974297
04/17/11 07:04 PM
04/17/11 07:04 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
i see no problems with your et goal.
the 4000 stall is ok,but a 5000 is better -worth about 1/10 on my 440.i picked up et and mph going from a 3.9 to a 4.1 gear,both with 28" tyre.
your motor doesn't know how old the 509 is,but your heads may appreciate a bit more lift.
i run 7 teens/twentys.
yes i shift at 6000
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: can we go over my 509 HYD combo? [Re: shoebox] #974298
04/17/11 07:26 PM
04/17/11 07:26 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I'm using the Crane rockers as they come out of the box and the 557 cam in my new 440.Works fine and is a reliable combo.
Nautilus Racing-
Re: can we go over my 509 HYD combo? [Re: Chris2581] #974299
04/18/11 10:08 AM
04/18/11 10:08 AM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
These are galled pretty good.....
Re: can we go over my 509 HYD combo? [Re: shoebox] #974300
04/18/11 02:37 PM
04/18/11 02:37 PM
I would, and have , send them to Rocker arm Specialitys, PH# 530-378-1075, and have them bush, rocker ratio changed to 1.6 and blueprinted Buy there shafts, bolts and hold downs at the same time, no more problems ever after that I use there bushed and blueprinted ductile iron rockers (of all brands)on a lot of my solid flat tappet and hydraulic lifter motors
Re: can we go over my 509 HYD combo? [Re: Cab_Burge] #974301
04/18/11 03:53 PM
04/18/11 03:53 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
I want to but that makes the bill 500.00 w pushrods
