Re: can we go over my 509 HYD combo?
[Re: shoebox]
#974297
04/17/11 07:04 PM
04/17/11 07:04 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
i see no problems with your et goal. the 4000 stall is ok,but a 5000 is better -worth about 1/10 on my 440.i picked up et and mph going from a 3.9 to a 4.1 gear,both with 28" tyre. your motor doesn't know how old the 509 is,but your heads may appreciate a bit more lift. i run 7 teens/twentys. yes i shift at 6000 Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: shoebox]
#974300
04/18/11 02:37 PM
04/18/11 02:37 PM
Posts: 43,336 Bend,OR USA
Cab_Burge
These are galled pretty good.....
I would, and have , send them to Rocker arm Specialitys, PH# 530-378-1075, and have them bush, rocker ratio changed to 1.6 and blueprinted Buy there shafts, bolts and hold downs at the same time, no more problems ever after that I use there bushed and blueprinted ductile iron rockers (of all brands)on a lot of my solid flat tappet and hydraulic lifter motors ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Cab_Burge]
#974301
04/18/11 03:53 PM
04/18/11 03:53 PM
Posts: 808 mckinney texas
shoebox
mckinney texas
I want to but that makes the bill 500.00 w pushrods
