Re: Pinion Angle - here we go....
[Re: 493_DART]
#973527
05/09/11 07:01 PM
05/09/11 07:01 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
well, i give up. Im taking the car to a pro measured again today: 1 method says 5 degrees down (wolfe) another method says 8 degrees down (trans yoke /pinion yoke) either way ive got too much angle
[Re: Sport440]
#973529
05/09/11 10:00 PM
05/09/11 10:00 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
[In MR.Pbodies car, he built his engine/tranny driveline paralell to the pinion. He and anyone else who does the same can accurately set the pinion angle off the Shaft.
People with Unmolested drivetrains can set the pinion angle off the shaft and still not have problems. Though the accuracy of the true pinion angle wont be known. As long as your getting a negative angle reading between the two of 3* to 5* or so. The U joints will do thier job and you wont notice anything most likely.
With a modified car such as yours, I think one can see you wouldnt want to measure it off the Shaft.
Your current measurements between the shaft and pinion give you a neg/-14*
Your current measurements between the tranny centerline and pinion give you a neg/-9*
"" Both sets of numbers are telling you, that your pinion angle is to far negative. If your measurments are "correct"""
[Re: DoctorDiff]
#973531
05/09/11 10:26 PM
05/09/11 10:26 PM
Posts: 387 Montreal PQ, Canada
74_360_Cuda
Montreal PQ, Canada
Probably stupid questions compared to yours but I was wondering:
I am going to install the Hotchkis Leaf springs, does it change significantly the amount of pinion angle I should try to get?
What about snubbers setting for street cars, would you adjust them to become in contact at 1 degree? 0 degree?
Also, I've read somewhere that when you remove a driveshaft from the transmission you have to put it back at the same place in order to be in phase... I really don't understand this, is in it how the driveshaft is welded together that determine the phasing and not how you clock the yoke in the transmission?
[Re: 493_DART]
#973534
05/10/11 01:51 AM
05/10/11 01:51 AM
493_DART
Worst Weather USA
SO,,,,,,,, Im at 8 degrees down ...... agree ?
[Re: 493_DART]
#973537
05/10/11 02:02 AM
05/10/11 02:02 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If you go by the trans/diff way its 8*... which is too much EDIT most of the cast yokes have a tapper cast into the area you show the protractor....you would have a truer reading on the front surface where the bolts mount
[Re: 493_DART]
#973538
05/10/11 04:15 AM
05/10/11 04:15 AM
Sport440
Canton, Ohio
SO,,,,,,,,
agree ?
Yes, From these numbers, your 8* down from tranny to pinion.
[Re: Al_Alguire]
#973539
05/10/11 04:52 AM
05/10/11 04:52 AM
493_DART
Worst Weather USA
Kevin I think you have finally found your true calling
Al -- are you making fun of my amazing artwork ???? !!! ???
HOW DARE YOU !!
[Re: 493_DART]
#973541
05/10/11 07:59 AM
05/10/11 07:59 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
most stock mopars i have checked, the trans is pointing down. and your 727 is really ugly
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: 493_DART]
#973542
05/10/11 11:09 AM
05/10/11 11:09 AM
MR_P_BODY
dammmm !!! another variable thrown into this ....... so now i need to pull the shaft and start over .... ? Mr. P - how much taper are we talking about ?? would you say 1 degree? 2 degrees ? we need a smiley figure that puts a gun in his mouth and blows his head off........
I dont really know... I never measured it but you can see it.... just trying to warn you... you can measure off the U-joint cap if you want... I made up a quick little tool for measuring off the cap but you can use a socket that fits and put your inclineometer on the socket... you will notice that one side is the pinion and the other is the drive shaft, just take the reading at the bottom(closest to the ground)
[Re: sixpackgut]
#973543
05/11/11 12:59 AM
05/11/11 12:59 AM
493_DART
Worst Weather USA
Im very hurt by your comments .....sitting in a pool of my own tears ........
