New SIXPACK STROKER Motor #972905
04/13/11 11:29 PM
04/13/11 11:29 PM
Alexandria, VA
E
easygoingjuan Offline OP
E
Alexandria, VA
Hello everyone, I just wanted to share a few pics of my new motor, a high compression stroked out 440 sixpack built by none other than Bob “The Man” Karakashian aka Mr. 6pk and his faithful sidekick/daughter Kim! I’m excited beyond belief. Mr. 6pk did an outstanding job and exceeded my hopes and expectations! He always kept my best interest in mind, answered all of my questions, and discussed every aspect of the build with me in detail. A true Mopar guy, Racer, and Friend. You’re one in a million Bob, thank you!
I’ll do my very best to keep everyone posted.
Re: New SIXPACK STROKER Motor [Re: easygoingjuan] #972906
04/13/11 11:30 PM
04/13/11 11:30 PM
Alexandria, VA
E
E
Alexandria, VA
No 2
Re: New SIXPACK STROKER Motor [Re: easygoingjuan] #972907
04/13/11 11:30 PM
04/13/11 11:30 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
What are the specs of the motor?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: New SIXPACK STROKER Motor [Re: easygoingjuan] #972908
04/14/11 10:53 AM
04/14/11 10:53 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
NIZZZZE but I'm bais
Coming soon!!!!
Re: New SIXPACK STROKER Motor [Re: easygoingjuan] #972909
04/14/11 11:52 AM
04/14/11 11:52 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Hello everyone, I just wanted to share a few pics of my new motor, a high compression stroked out 440 sixpack built by none other than Bob “The Man” Karakashian aka Mr. 6pk and his faithful sidekick/daughter Kim Karakashian! I’m excited beyond belief. Mr. 6pk did an outstanding job and exceeded my hopes and expectations! He always kept my best interest in mind, answered all of my questions, and discussed every aspect of the build with me in detail. A true Mopar guy, Racer, and Friend. You’re one in a million Bob, thank you!
Heads?, Cam?
Now, it’s time for me to put this bad boy in the Bee and see what she’ll do!!!!!!!!!!!!!!!!!!! I’ll do my very best to keep everyone posted.
Re: New SIXPACK STROKER Motor [Re: BobR] #972910
04/14/11 12:28 PM
04/14/11 12:28 PM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
what are the specs? i will bet you dollars to donuts, not all of the aspects of the build were shared with the op . cam specs maybe? nice looking engine by the way, except for the painted over chrome thermastat housing, surely gonna peel .
Re: New SIXPACK STROKER Motor [Re: BobR] #972911
04/14/11 11:19 PM
04/14/11 11:19 PM
Alexandria, VA
E
E
Alexandria, VA
Heads?, Cam?
Cam is a custom Mr.6pk grind as well as the heads. Thanks for the interest.
Juan
Re: New SIXPACK STROKER Motor [Re: 70sixpkrt] #972912
04/14/11 11:22 PM
04/14/11 11:22 PM
Alexandria, VA
E
E
Alexandria, VA
Thank you for the interest but I thought I'd leave the specs for the track.
Re: New SIXPACK STROKER Motor [Re: Mr.Yuck] #972913
04/14/11 11:23 PM
04/14/11 11:23 PM
Alexandria, VA
E
E
Alexandria, VA
Hello, that's a nice set up you have in your Charger. Thanks for the compliment.
Juan
Re: New SIXPACK STROKER Motor [Re: easygoingjuan] #972914
04/14/11 11:24 PM
04/14/11 11:24 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
what are you hoping to run at track?
MOPAR OR NO CAR
Re: New SIXPACK STROKER Motor [Re: easygoingjuan] #972915
04/14/11 11:38 PM
04/14/11 11:38 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
y/w...mines a .030 over 440 11.25:1, ported Stage VI heads, Comp cams 588 solid roller, Meth injection, 3800 Turbo action, man valve body and 3.91's.
Re: New SIXPACK STROKER Motor [Re: hemigod426] #972916
04/14/11 11:39 PM
04/14/11 11:39 PM
70sixpkrt Offline
70sixpkrt  Offline
Me too.
4-speed
3:54 Dana
Re: New SIXPACK STROKER Motor [Re: Mr.Yuck] #972917
04/14/11 11:47 PM
04/14/11 11:47 PM
hemigod426 Offline
hemigod426  Offline
what does this yours run in 1/4 in full weight 1970 b-body?
MOPAR OR NO CAR
Re: New SIXPACK STROKER Motor [Re: hemigod426] #972918
04/14/11 11:51 PM
04/14/11 11:51 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
let you know soon. I had an issue with the Moroso valve covers and the H/S rockers. It's not quite full weight. I has a glass hood. front valance and no heat/ac box. I think it should run 11.50's once I get it tuned in.
Re: New SIXPACK STROKER Motor [Re: Mr.Yuck] #972919
04/15/11 12:08 AM
04/15/11 12:08 AM
hemigod426 Offline
hemigod426  Offline
do the harland sharp rockers fit with stock 1970 covers just bought a set of 1.5s for my 1970 440 sixpack motor?
MOPAR OR NO CAR
Re: New SIXPACK STROKER Motor [Re: hemigod426] #972920
04/15/11 02:42 AM
04/15/11 02:42 AM
Cab_Burge Online work
Cab_Burge  Online Work
Probally not
Re: New SIXPACK STROKER Motor [Re: hemigod426] #972921
04/15/11 10:35 AM
04/15/11 10:35 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm going to say no. Not w/o some serious .
Re: New SIXPACK STROKER Motor [Re: hemigod426] #972922
04/15/11 08:30 PM
04/15/11 08:30 PM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
The Harland Sharps with work with easy mods. One would be to remove the baffel completly the other is to just drill 3/8th holes where the studs are. If you remove the baffel completly you should make a sheild at least where the breather is. Other then that it's a home run.
Jaun looks great good luck!
Ed
Re: New SIXPACK STROKER Motor [Re: XXHEMI] #972923
04/15/11 10:02 PM
04/15/11 10:02 PM
Alexandria, VA
E
E
Alexandria, VA
Thank you Ed, I'm very happy as you can imagine.
Re: New SIXPACK STROKER Motor [Re: XXHEMI] #972924
04/15/11 10:59 PM
04/15/11 10:59 PM
hemigod426 Offline
hemigod426  Offline
Ed
thanks good info, was thinking moving whole baffle up and rewelding it
MOPAR OR NO CAR
