Check out this twin turbo V8 #972557
04/13/11 02:03 PM
04/13/11 02:03 PM
Fly Over States
P
PHJ426 Offline OP
PHJ426  Offline OP
P
Fly Over States
Re: Check out this twin turbo V8 [Re: PHJ426] #972558
04/13/11 03:27 PM
04/13/11 03:27 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
- Stu Harmon
Re: Check out this twin turbo V8 [Re: feets] #972559
04/13/11 08:42 PM
04/13/11 08:42 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Looks like the headers ought to do a real good job of heating the inlet air to and from the intercooler.Especially when the engine cover is all closed up.
Re: Check out this twin turbo V8 [Re: feets] #972560
04/14/11 12:40 AM
04/14/11 12:40 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I bet it flies. No weight to speak of and tons of potential.
I'm sure we'd have a whole bunch of people pointing out what I did wrong on any of my builds if they were posted in such detail.... so I sure don't want to be too critical of any of it.
I will say though that those turbos will not like it when they ingest the foam from those air filters. Been there done that! There's lots of things about that build that I personally would do differently, but we all have to learn somehow. You know full well it will be a BLAST to drive! Thanks for posting that!
Re: Check out this twin turbo V8 [Re: Duner] #972561
04/14/11 08:57 PM
04/14/11 08:57 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
He's gonna have some real problems running those wastegates with the flow in the wrong direction.
Re: Check out this twin turbo V8 [Re: TRENDZ] #972562
04/14/11 09:23 PM
04/14/11 09:23 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
I think its an awesome ride....but why not build a 6.0 LS based motor with a kenne belle or a set of twins? Could have saved the guy thousands, been less exotic, and ran fine on pump premium. Why the tricked out kinsler setup if your going to hide it with that huge plenum I guess when money is no object things can get out of hand lol
Re: Check out this twin turbo V8 [Re: feets] #972563
04/14/11 11:46 PM
04/14/11 11:46 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I dunno..I'm no expert, but it seems it could have been done much better and w/o as much pipe? Am I wrong?
Coming soon!!!!
Re: Check out this twin turbo V8 [Re: Mr.Yuck] #972564
04/15/11 12:02 AM
04/15/11 12:02 AM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
Yeah I agree it is not well setup. I would have done a air to water intercooler built into the top side of the manifold with one inlet. I always wanted to build one of those cars or a cobra...
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: Check out this twin turbo V8 [Re: TRENDZ] #972565
04/15/11 01:32 PM
04/15/11 01:32 PM
IL
furious70 Offline
furious70  Offline
IL
Good catch....the build is so old according to the page you would have thought they'd have started it and realized that by now.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Check out this twin turbo V8 [Re: furious70] #972566
04/15/11 08:34 PM
04/15/11 08:34 PM
Fly Over States
P
PHJ426 Offline OP
PHJ426  Offline OP
P
Fly Over States
I found it interesting how they put the forced air into the top of the airbox on the intake.
Re: Check out this twin turbo V8 [Re: PHJ426] #972567
04/16/11 10:25 PM
04/16/11 10:25 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
the correct way with twins is to blow them at each other when entering the plenum
home of the
Sox and Martin Hemi Duster
Re: Check out this twin turbo V8 [Re: HEMIFRED] #972568
04/16/11 10:33 PM
04/16/11 10:33 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
home of the
Re: Check out this twin turbo V8 [Re: SLOW67] #972569
04/17/11 12:36 PM
04/17/11 12:36 PM
Oxford, OH
Blue93Dakota Offline
Oxford, OH
You mean like this:
http://www.schwartzperformance.com/projects.aspx?projectid=18
Been on the PowerTour the past 4 years and it's always there. Very tight efficient looking setup.
Not to crap on that setup pictured above, but wouldn't there be a ton of force trying to rip that big flat top off at 15psi with all the surface area there?
93 Dakota Club Cab R3 Turbo Build in progress
Re: Check out this twin turbo V8 [Re: Blue93Dakota] #972570
04/25/11 06:08 PM
04/25/11 06:08 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Lots of things we could say were done 'wrong' (Trendz comment made me review pics of mine to make sure my wastegate was installed corrctly!), but I think that's a beauty of turbo stuff. Even a less-than-ideal installation still works, apparently.
For me, I think getting cool outside air to the turbos would reduce teh need for that intercooler, and reduce a lot of plumbing that is probably working as an interheater (as 67 Satellite mentioned).
