Re: some help starting new engine
[Re: drumcat]
#971693
04/12/11 09:22 PM
04/12/11 09:22 PM
RapidRobert
problem now is i do not have spark from the coil wire....power to +side is there although seemingly weak...a way to test coil?
Hold coil secondary wire (dist end) 1/4" from a ground and jump 12V from batt positive post over to the coil (+) pri terminal and w another jumper wire w alligator clips on each end connect one end to the coil (-) pri terminal and touch the other end to ground making and breaking it repeatedly like Morse Code & see if this makes the coil secondary wire spark. A coil can test OK cold like this then act up w hot but this'll see if you have continuity as is. EDIT Then need switched 12V to coil positive thru the ballast in run (ign1) and 12V to it bypassing the ballast in start (ign2) and the ECU needs to make/break the coil pri negative terminal like you did by hand and the dist pickup triggers the ECU to do this.
