Re: 2.76 posi????
[Re: Kern Dog]
#971536
04/12/11 03:41 AM
04/12/11 03:41 AM
Posts: 30,632 Florida STAYcation
IcorkSOAK
Financed his waterbed
Florida STAYcation
Short legs move faster to cover the same distance.
You have-been ....haven't you ? ...
To compare legs on a human to a gear ratio ?
U R a phunny and WEIRD guy !
Re: 2.76 posi????
[Re: Kern Dog]
#971538
04/12/11 03:52 AM
04/12/11 03:52 AM
IcorkSOAK
Florida STAYcation
....... my typing skills are impeccable.
Oh really ? DID you ferrget to use yurr speal-chuck today ?
Re: 2.76 posi????
[Re: quickd100]
#971540
04/12/11 08:07 AM
04/12/11 08:07 AM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
I've got a 741 case 2.76 SG (power lok) sitting in a five gallon bucket in my garage. Ran it in my Challenger last year for the Power Tour. Keep it around just for that purpose. You can only imagine the top end on a 440 Six Pack Challenger running 2.76s. BTW, short gears ARE numerically higher ratios, just like low gear in your transmission is numerically higher.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: 2.76 posi????
[Re: 471Magnum]
#971541
04/12/11 10:01 AM
04/12/11 10:01 AM
IcorkSOAK
Florida STAYcation
At 7:07am in the morning ? ...... so early ...
But WHAT else can you Xpect from a self-professed space cadet/cowboy .....
...... but if you want to call an apple ...a banana ... that beez OK by me ....
Re: 2.76 posi????
[Re: Twostick]
#971543
04/12/11 10:09 AM
04/12/11 10:09 AM
IcorkSOAK
Florida STAYcation
This is what happens children when you work with fiberglass resin and don't use a respirator.
Kevin
..... OR if you live in Canukada, have brain-freeze(due to the still-cold temps) and live in a town with a name like Sears-Roebuck !! ...
Re: 2.76 posi????
[Re: Twostick]
#971544
04/12/11 10:22 AM
04/12/11 10:22 AM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
Kevin
No kidding ...
Re: 2.76 posi????
[Re: JohnRR]
#971545
04/12/11 10:29 AM
04/12/11 10:29 AM
IcorkSOAK
Florida STAYcation
Kevin
No kidding ...
Oh YEAH ... the consumption of same sure allows certain people the skill to put select internet "bullies" and Dbags IN THEIR PLACE.
Re: 2.76 posi????
[Re: IcorkSOAK]
#971546
04/12/11 11:13 AM
04/12/11 11:13 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
As wierd as it may be to some people, the tall gears WITH a sure grip offer the driver freeway economy and traction in the snow. Then again, I live in California. I dont see much snow anyway.
FRANKENberri ... Yes - you are WEIRD !! .... a 2.76 gear is a very SHORT gear ...not TALL.
Do I have to learn you EVERYthing ? ..
no, tall or high gearing is numerically low...less mechanical advantage, more speed per RPM
short or low gearing is numerically high, with more mechanical advantage, but less speed per RPM.
if this is for a cruiser, a 2.76 limited slip, with a good higher stall (say, 3500RPM) but "tight" (not a lot of slip at part throttle) works very well, giving decent highway RPM, and plenty of torque for launching and accelerating.
Re: 2.76 posi????
[Re: patrick]
#971547
04/12/11 12:24 PM
04/12/11 12:24 PM
IcorkSOAK
Florida STAYcation
good higher stall (say, 3500RPM) but "tight" (not a lot of slip at part throttle) GOT that right .... but the rest ? .... NOT-so-much .... HOW can you be so uNcorrect ?
Re: 2.76 posi????
[Re: IcorkSOAK]
#971548
04/12/11 05:20 PM
04/12/11 05:20 PM
patrick
Grand Haven, MI
GOT that right ....
but the rest ? ....
stall speed is where you get maximum torque multiplication....the closer you get to your peak torque RPM, the more the multiplication to get the car moving. the taller gears make it sane to drive at reasonable highway speeds. my 5th ave, with 3.55's and 27" tall tires with 3.55's and a lockup 904 buzzed at 3300 RPM on the freeway here in MI (75mph). was very fatiguing to drive more than about 20 miles. a 2.76 drops it to a more reasonable 2550 RPM.
also, higher (lower numerically) gears are stronger, because the ring gear teeth are larger.
Re: 2.76 posi????
[Re: gregn96cuda]
#971550
04/13/11 03:37 AM
04/13/11 03:37 AM
Posts: 550 SW Missouri
moparmandjh
SW Missouri
I have a 2.76 sg in my 440 daily driven short bed, I want 3.55 for all the hills around here. Doc
American soldiers in battle don't fight for what some president says on tv, they don't fight for mom, apple pie, or the American flag... they fight for one another. -Lt. General Hal Moore
Re: 2.76 posi????
[Re: john55]
#971553
04/13/11 11:26 AM
04/13/11 11:26 AM
Posts: 12,478 Kalispell Mt.
HotRodDave
Kalispell Mt.
I pulled my 2.76 SG chunk from a c-body rear. I love it with the 360 in the cuda If a 440 needs 3.55s for hills you must have a puny, almost dead 440, you need a tune up or something, my 360 pulls up the going to the sun road in glacier national park in 3rd like no ones buisness, very steep and fairly high elevation, breath takeing road.
Re: 2.76 posi????
[Re: IcorkSOAK]
#971554
04/13/11 10:45 PM
04/13/11 10:45 PM
Posts: 6,621 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Kevin
But I own 25% of the downtown core... Too bad there is only the one intersection.
Kevin
Re: 2.76 posi????
[Re: HotRodDave]
#971555
04/14/11 01:00 AM
04/14/11 01:00 AM
moparmandjh
SW Missouri
Its just all straight up and down around here. Got plenty of power just wanting to improve my mpg a little. You know big cam, stall, tall intake, plus the 2.76 gears sucks in the hills. Put the engine in a more usable rpm range, if I was a freeway flyer they would be great.
