Re: 1965 / 1966 Fury's ..what tire size have you used [Re: SPWC] #96966
07/31/08 12:53 AM
07/31/08 12:53 AM
Cochise County Arizona
SPWC Offline
SPWC  Offline
Another view from the rear. On the fronts im running a 215/70/15
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: SPWC] #96967
07/31/08 09:09 AM
07/31/08 09:09 AM
S.E. South Dakota !
bigdad Online content OP
Still Posting A Lot
bigdad  Online Content OP
Still Posting A Lot
S.E. South Dakota !
do you have a side view of it ?
I'm not worried about rubbing, worried about getting them on
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: bigdad] #96968
07/31/08 11:33 AM
07/31/08 11:33 AM
SPWC Offline
SPWC  Offline
Side view,If you need any other pics just ask
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: SPWC] #96969
07/31/08 11:51 AM
07/31/08 11:51 AM
S.E. South Dakota !
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
big improvement
Don't suppose you have a closer view
even if it was just the tire(s) and wheel(s)
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: bigdad] #96970
07/31/08 11:55 AM
07/31/08 11:55 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Forget the steelies...you know you want to
(these 17" TTO copies are not a bad price..)
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: bigdad] #96971
07/31/08 12:01 PM
07/31/08 12:01 PM
SPWC Offline
SPWC  Offline
As requested--
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: SPWC] #96972
07/31/08 12:02 PM
07/31/08 12:02 PM
SPWC Offline
SPWC  Offline
Another
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: SPWC] #96973
07/31/08 12:04 PM
07/31/08 12:04 PM
S.E. South Dakota !
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Also, there is two 65 wagons laying in the weeds by here that if needed can get parts off of
The one, I prefer to wait till cooler weather would show up
cause , I think its most likely a snake house
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: SPWC] #96974
07/31/08 12:05 PM
07/31/08 12:05 PM
SPWC Offline
SPWC  Offline
Front
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: SPWC] #96975
07/31/08 12:06 PM
07/31/08 12:06 PM
SPWC Offline
SPWC  Offline
Ya know those are nice but EVERYONE has those,my only issue with those wheels
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: SPWC] #96976
07/31/08 12:07 PM
07/31/08 12:07 PM
S.E. South Dakota !
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
As requested--
Those look good, guy could go bigger too huh ?
How hard where they to get on past the brake drum ?
Oz, what do those wheels sell for $$ ?
I know you don't worry about money but, I DO
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: bigdad] #96977
07/31/08 12:11 PM
07/31/08 12:11 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Around $800 a set for 17's
'in guy like you would be able to swing a few sets I'm sure..
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: bigdad] #96978
07/31/08 12:11 PM
07/31/08 12:11 PM
SPWC Offline
SPWC  Offline
The rears are a little tricky,putting on and off,gotta lift the car up a lttle bit,but otherwise they went on fine. Figuring you already have that silver car with big ol back tires,compared to that,changing tires on the back of my wagon is a breeze.
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: SPWC] #96979
07/31/08 12:19 PM
07/31/08 12:19 PM
S.E. South Dakota !
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
This thing is a MAJOR job to put rears on
We have to put it on a 4 post lift and use the jack to lift it way in the air , drop shock bolts
Unhook brake line brackets ..
But, the wagon is different, if you ae driving and have a flat, well . then what ?
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: OzHemi] #96980
07/31/08 12:23 PM
07/31/08 12:23 PM
S.E. South Dakota !
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
200 a piece for knock offs ?
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: bigdad] #96981
07/31/08 02:46 PM
07/31/08 02:46 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
These are USA made (local) and believe real TT's are up there abit too (and think these are like $195 per?)
The American Eagle versions where right around the same price, but they are not going to be around for long..(and hard to get now with production way down on them)
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: bigdad] #96982
07/31/08 02:53 PM
07/31/08 02:53 PM
SPWC Offline
SPWC  Offline
I jack the car up by the front leaf spring mount with a floor jack.
