Plunge cut for heads #968684
04/07/11 06:16 PM
04/07/11 06:16 PM
Up in the North and Far Away
AutoEngineer Offline OP
Hi guys,
Could you please give good advice about plunge cut of cast iron 906 heads?
How deep the cut should be and correct angle?
Re: Plunge cut for heads [Re: AutoEngineer] #968685
04/08/11 08:28 AM
04/08/11 08:28 AM
Merrill, WI
440CIVIC Offline
440CIVIC  Offline
Merrill, WI
On my 915's I cut a 75* angle .590 deep but I did it on a cnc machine and used a circular interpolation cycle to hit my dia. I left .015 of 45* per side of land to the valve contact area. Did the same with the 30* blend to the chamber. I have read that some run 80* but that would get to close to water for me, the 75* left a good notch in the bowl to blend. I can post a pick when I get home.
Re: Plunge cut for heads [Re: 440CIVIC] #968686
04/08/11 11:29 AM
04/08/11 11:29 AM
Thanks , it would be fine to see pictures from your heads
Re: Plunge cut for heads [Re: AutoEngineer] #968687
04/08/11 05:20 PM
04/08/11 05:20 PM
Merrill, WI
440CIVIC Offline
440CIVIC  Offline
Merrill, WI
Pic after cut
Re: Plunge cut for heads [Re: 440CIVIC] #968688
04/08/11 05:22 PM
04/08/11 05:22 PM
Merrill, WI
440CIVIC Offline
440CIVIC  Offline
Merrill, WI
Pic after porting
