alternator not charging??
#967358
04/05/11 11:01 PM
04/05/11 11:01 PM
Posts: 4,701 On the parachute mount
n20mstr
IF the alt is no good....can i tell by just jumping the field wires right at the alt?? Also when running if i put a screwdriver to the back it has no magnetic pull, is the alt no good??
....BAD A$$ STREET CAR.....
Re: alternator not charging??
[Re: n20mstr]
#967359
04/05/11 11:05 PM
04/05/11 11:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you full field it and nothing happens the alt is not working(if it was working before... thats not taking in any possible broken trigger wire) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#967360
04/05/11 11:18 PM
04/05/11 11:18 PM
n20mstr
yes MrP it was working before, but its prob a 4 or more year old rebuilt that i had laying around. My sons duster is just about finished, ready to drive to school for the first time tomorow and.....its not charging..I told him "hey at least you didnt get stuck in th school parking lot..LOL
[Re: n20mstr]
#967362
04/05/11 11:37 PM
04/05/11 11:37 PM
MR_P_BODY
I assume this is basically a production ride ... if so just replace it with a stock type unit... sounds like its a older Mopar... see if you can get a higher output one from the auto parts store... I believe the highest in the stock case is a 75 amp ![](/ubbthreads/images/graemlins/wave.gif)
[Re: n20mstr]
#967363
04/05/11 11:46 PM
04/05/11 11:46 PM
RapidRobert
I'd take out both brush holders/brushes for a 1 minute look see & replace them back in. Set car on fast idle and jump from the batt positive terminal to either male field terminal and the other male field terminal over to batt neg post or a nearby KNOWN good ground for several seconds MAX and if this "full fielding" makes it charge/max out then the alt is good and it is a field wiring/v reg prob & if not the alt needs to come apart/or a diff one and as said a charging alt will have magnetic pull in the back center on a screwdriver EDIT I think the highest amp OE type unit that will bolt right in w your existing brackets is a 78amper from a 80's M body, not sure on the app (yr/make) so check that
