ALUM DOOR PANELS PREP #966135
04/04/11 08:34 PM
04/04/11 08:34 PM
OH
junkyardmaxie Offline OP
OH
HELLO MY DUSTER HAS ALUM DASH AND DOOR PANELS. WHAT NEEDS TO BE DONE IN THE WAY OF PREP, FOR A NICE JOB, : AND TO GET THE PAINT TO STAY ON? THANKS
Re: ALUM DOOR PANELS PREP [Re: junkyardmaxie] #966136
04/04/11 11:24 PM
04/04/11 11:24 PM
Missouri
Challenger Offline
Challenger  Offline
Missouri
Clean aluminum with waterborne wax and grease remover, never with lacquer thinner or reducer. Sand with 80 grit DA paper, reclean with waterborne wax and grease remover, wait 30-60 minutes and apply a epoxy primer. I personally use Southern polyurethanes epoxy primer. www.southernpolyurethanes.com Hope this helps! Then paint!
Re: ALUM DOOR PANELS PREP [Re: junkyardmaxie] #966137
04/05/11 02:09 AM
04/05/11 02:09 AM
OH
OH
THANKS FOR THE HELP
Re: ALUM DOOR PANELS PREP [Re: junkyardmaxie] #966138
04/05/11 02:22 AM
04/05/11 02:22 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I use 220 grit and wipe with MEK or Acetone and a brown scotchbrite pad, and depending on what paint you want, if its laquer, dust it with zinc chromate first, if wanting to use eurothane or epoxy, Dupont DP40 or 48 is self etching and works great. I use it on aircraft skins all of the time.
Re: ALUM DOOR PANELS PREP [Re: junkyardmaxie] #966139
04/05/11 10:55 AM
04/05/11 10:55 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Use this stuff, it'll make sure the aluminum is ready for paint.
