harness connecter from column to dash replace/repair? #963082
03/31/11 02:05 PM
03/31/11 02:05 PM
Jacksonville, NC
RonP Offline OP
RonP  Offline OP
Jacksonville, NC
73 Satellite
This past week I finally got the cloumn put back in the car after and when I went to reconnect the white connecter from cloumn to dash, it actually broke in two. (btoh sided of the main hot pin) so now I have two pieces and the red lead pin all separate. I had a feeling it was going to happen because it showed signs of burning/melting. At some point long ago when my dad owned this car something made that main wire get hot and start this damage.
is that connector or column side piece available? should I just cut both ends off and look for a replace connector of some sort with appropriate amount of connections?
open to all suggestions.
thanks
Re: harness connecter from column to dash replace/repair? [Re: RonP] #963083
03/31/11 03:17 PM
03/31/11 03:17 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
is it for the ignition switch?
Re: harness connecter from column to dash replace/repair? [Re: mopars4ever] #963084
03/31/11 03:31 PM
03/31/11 03:31 PM
Jacksonville, NC
RonP Offline OP
RonP  Offline OP
Jacksonville, NC
Not sure what this one does. There is a white one and a blue one that is smaller and thinner. They both come out of the coulumn and plug into the big dash harness. I will take a pic tonight maybe.
Re: harness connecter from column to dash replace/repair? [Re: RonP] #963085
03/31/11 11:20 PM
03/31/11 11:20 PM
md
md
Blue is the turn signal switch IIRC. What end do you need? Column end or dash harness end? If you need the column end you can buy a new ignition switch and replace the whole piece. I believe the connector is available separate but I can`t remember where I have seen them.
Re: harness connecter from column to dash replace/repair? [Re: mopars4ever] #963086
04/01/11 02:00 AM
04/01/11 02:00 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Better to have a new ignition switch, especially if in the past some overheat/semi-melting action took place. If so, it's a matter of time before the switch itself takes a dump. If it's the dash side of the harness connector, a couple of options:
1) the right (and most expensive) way; get a new harness.
2) semi-econo way: used harness from JY off 73 (or 71-74 B-Body) - as usual, YMMV as far as interchangeability.
3) econo way: get harness connector cut off from JY vehicle and splice, solder, heat-shrink tubing wrap each wire on JY connector to existing harness in car.
4) Super-econo way: trim off smaller half of plastic on existing broken connector, heat shrink tubing on wires with terminals that are "uncontained" up to just short of where they are buried in column connector, and figure out some means of holding them in the connector when connected.
