Head studs 9/16 #961784
03/29/11 04:23 PM
03/29/11 04:23 PM
QLD Australia
Keith Black® Offline OP
QLD Australia
I am soon to order a new KB water Hemi block and understand that several options exist for head studs & would appreciate opinions.
7/16 - 1/2 - 9/16...?
On my application , which will be blown street motor not seeing more than 15psi, any benefits/disadvantages in going to the largest stud size? final Bore size will be 4.310 to keep some meat between cylinders for better long term gasket sealing,. would you o-ring a street motor? or just good composite gasket?
help appreciated
Darren Beale
Keith Black Racing Engines®
Re: Head studs 9/16 [Re: Keith Black®] #961785
03/29/11 06:57 PM
03/29/11 06:57 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We use 1/2 head studs for our blower builds.Our next build a 540" Hemi for Donny's 65 Dodge will use Cometic gaskets instead of our usual copper and O-ring/reciever groove setups.
