Single vs Twin Plumbing #961386
03/29/11 12:23 AM
03/29/11 12:23 AM
Liverpool, NY
SILVER67 Offline OP
SILVER67  Offline OP
Liverpool, NY
Hey Guys,
I have a '67 B-body. Was just curious if it is easier to plumb two small turbos or one turbo? It looks like you use one turbo for each bank on a twin turbo setup. And all eight cylinders into one on a single turbo set up.
Michael
Re: Single vs Twin Plumbing [Re: SILVER67] #961387
03/29/11 03:23 AM
03/29/11 03:23 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Depends of how you do it. If you can build one, you can build both.
Plynouth VIP '67 TT IC EFI
Re: Single vs Twin Plumbing [Re: jyrki] #961388
03/29/11 12:52 PM
03/29/11 12:52 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
There's a thread somewhere in this section with pics of a 67 Belv or GTX, green in color.
Re: Single vs Twin Plumbing [Re: Fury Fan] #961389
03/29/11 03:34 PM
03/29/11 03:34 PM
Borden, Indiana, U.S.A.
W
wrenchinrandy Offline
W
I agree with Jyrki, if you can build one then you can build either. I put twins on my '67 Charger because it worked out better for my build. I wanted to keep the factory accessory drives for instance. Either is doable. Good luck!!
Re: Single vs Twin Plumbing [Re: wrenchinrandy] #961390
03/29/11 04:42 PM
03/29/11 04:42 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I would say the twins plumbing is a bit easier than a single...
Re: Single vs Twin Plumbing [Re: Fury Fan] #961391
03/29/11 10:24 PM
03/29/11 10:24 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Re: Single vs Twin Plumbing [Re: 67_Satellite] #961392
03/29/11 11:43 PM
03/29/11 11:43 PM
Liverpool, NY
SILVER67 Offline OP
SILVER67  Offline OP
Liverpool, NY
YESS!
I have a '67 Coronet. Thats my kind of look as well.
Michael
