70 cuda shaker fresh air cable routing? #960956
03/28/11 02:39 PM
03/28/11 02:39 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
i am not sure how to run the fresh air cable from the dash to the shaker on a 70 cuda. i have 2 cables that are supposed to be for working the flaps on the shaker. one has the handle that bolts to the dash and goes through the firewall. i think the hole is close to the middle of the firewall at the top. the cable looks long enough to reach the shaker but there is another shorter one that came with it. i am not sure how they work together.
also the rubber groument that goes in the firewall for the cable has a small hole but the cable has a plastic tab on the end to bolt to something and will not fit through the hole?
anyone have a picture or good description of how it works?
thanks
Re: 70 cuda shaker fresh air cable routing? [Re: dirt] #960957
03/28/11 03:26 PM
03/28/11 03:26 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Hope these help.
Re: 70 cuda shaker fresh air cable routing? [Re: Snoopy] #960958
03/28/11 03:27 PM
03/28/11 03:27 PM
Snoopy Offline
Snoopy  Offline
2
Re: 70 cuda shaker fresh air cable routing? [Re: Snoopy] #960959
03/28/11 03:28 PM
03/28/11 03:28 PM
Snoopy Offline
Snoopy  Offline
3
Re: 70 cuda shaker fresh air cable routing? [Re: Snoopy] #960960
03/29/11 07:18 AM
03/29/11 07:18 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
yes that helps a lot,thanks for posting those pictures.
