Cordoba 9-1/4 #959940
03/27/11 03:28 PM
03/27/11 03:28 PM
Boise Idaho
Boise Chall Offline OP
Boise Idaho
I finally found a 9-1/4 for my 73 Roadrunner the rear is out of a 75 Cordoba I'm told it will fit.... Will it ? I will measure before I buy it. The Cordoba rear has highway gears in it so I will need to change them. What years of 9-1/4 can I get get the gears out of ? I want 3:55 gears Can I get them out of a newer truck ?
Re: Cordoba 9-1/4 [Re: Boise Chall] #959941
03/27/11 09:33 PM
03/27/11 09:33 PM
central CT
cudazappa Offline
cudazappa  Offline
central CT
The 9.25 in the late bs came with a 3.23 gear. The 8.25 would have either 2.45s or 2.76s in it.
The rear is pretty much a bolt in swap on your 73 (maybe not driveshaft, I'm unsure of the snout length difference)
1971 Challenger
Re: Cordoba 9-1/4 [Re: cudazappa] #959942
03/27/11 10:53 PM
03/27/11 10:53 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Not all 9 1/4's came with 3.23's.
I had a Magnum GT some years back, 318 t-top car, and for whatever reason, it had 2.76 gears, and it was an 9 1/4. But what Czappa said, it should be a pretty much "plug and play".
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Cordoba 9-1/4 [Re: Magnumguy] #959943
03/28/11 12:43 AM
03/28/11 12:43 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
From what I've read online, the diff should drop right in. AFAIK rear gears will fit all years of 9.25's from the 70's until the 2000's.
Re: Cordoba 9-1/4 [Re: DaytonaTurbo] #959944
03/28/11 02:55 AM
03/28/11 02:55 AM
Boise Idaho
Boise Idaho
Thank you for the replies. I picked up the rear end the measurements of the housing are a perfect match to the 8-1/4 in the car now. The gears in the rear are 3:21 I can deal with that for now. The input shaft bearing feels like it's wasted But I've always wanted to learn how to rebuild a rearend now it looks like I'll get my chance. I'm sure I'll have questions when I get to the rebuild.
Re: Cordoba 9-1/4 [Re: Boise Chall] #959945
03/29/11 02:44 PM
03/29/11 02:44 PM
MD
ADakotaRTGuy Offline
MD
Want to get rid of those 3.23's? I could use those for my turbo truck. I would offer up the 3.92's I have but can't pull them out anytime soon.
