Thermoquad adapter to AVS #959734
03/27/11 09:57 AM
03/27/11 09:57 AM
birdtracker Offline OP
Is there a easy find to replace my worn out thermoquad with a new Edelbrock style carb? thanks. Birdtracker
Re: Thermoquad adapter to AVS [Re: birdtracker] #959735
03/27/11 10:47 AM
03/27/11 10:47 AM
Buy the thin flat adapter plate to convert the intake spreadbore flange. If one of your parts houses has an Edelbrock carb accessories rack it'll b there. It's cheap & covers the bowed out area on the secondaries. use a thin gasket then the plate then another thin gasket then either a thick felpro gasket then the carb or just the carb w no thick gasket depending on hood clearance & the thick Felpro helps alot w heat soak if it'll fit
