Re: Need advice / ideas on trimming torsion bar crossmember
[Re: DAYCLONA]
#959114
05/08/11 09:49 AM
05/08/11 09:49 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
.....2 questions for you, placement of the motor mount brackets, behind, or infront of the engines mounting tab/bosses/ears when veiwing the engine from the front,...next, are you running a 70 B body K frame in a 69 Charger
Mike why would a 70 B body K frame make a difference , it's the same K used in 69 starting sometime in March of 69?
I'm having a hard time believing that others don't have this issue with the Kielser install.
69, have you confirmed that your driveshaft angles are correct now? Nice work , can't wait to see the finished floor tunnel.
[Re: RTSE4ME]
#959116
05/08/11 01:05 PM
05/08/11 01:05 PM
Posts: 1,523 Oakley CA
69charger440_6pa
Oakley CA
The tranny is raised up to the factory position of the old 4 speed. I think I have about 2" of spacers from keisler inbetween the tranny and the mounting braket.
1969 Charger R/T under construction 2014 Ram 3500 Cummins 2006 Corvette Z06 2015 Corvette Z06 2014 BMW M5
