Page 1 of 3 1 2 3
Low, low budget 10 sec rides #958306
03/25/11 07:54 AM
03/25/11 07:54 AM
S.W. PA
6PACMAC Offline OP
6PACMAC  Offline OP
S.W. PA
Lets see your low dollar 10 second cars and what is the combo!
Re: Low, low budget 10 sec rides [Re: 6PACMAC] #958307
03/25/11 10:33 AM
03/25/11 10:33 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Can you define "low dollar" and is there a minimum weight requirement?
Re: Low, low budget 10 sec rides [Re: BradH] #958308
03/25/11 10:43 AM
03/25/11 10:43 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
My old Duster....3270# Dana 4.56's...Caltracs...13/31 Mickeys...9.5-1 446...TRW slugs...MP.509...Proform bodied 750...2" Hooker fenderwalls...M1...OOTB Eddy RPM's...Coan 5200 stall...727 w/Tranzact brake...
Car ran 10.60's at 124 on 100 octane pump gas 1.40 60's
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Low, low budget 10 sec rides [Re: 6PACMAC] #958309
03/25/11 10:45 AM
03/25/11 10:45 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
That's a bit of a oxymoron isn't it?
Re: Low, low budget 10 sec rides [Re: 72demon416] #958310
03/25/11 10:53 AM
03/25/11 10:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Just make the car light enough and you could probably
do it with a stock 318
Re: Low, low budget 10 sec rides [Re: 6PACMAC] #958311
03/25/11 12:16 PM
03/25/11 12:16 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
low weigh a-body... 10:1 440, 509 hydro or 557 solid cam, decent heads, 1 7/8 headers, 3800 stall, good trans w/ manual valve body and 4.10's That should get you in the 10's. Not sure it's all that cheap. I guess one could build a mid-11 second motor and hit it w/ a 150 shot too.
Coming soon!!!!
Re: Low, low budget 10 sec rides [Re: 6PACMAC] #958312
03/25/11 12:36 PM
03/25/11 12:36 PM
organ
maximum entropy Offline
organ
low dollar is relative. i've done it as cheaply as humanly possible, but it ain't cheap. i've used good parts, and have done all the work myself. i haven't added up my receipts because i don't want to, but count on spending ~7 large on the engine (at least), 2 grand on the tranny, 2 grand on the rearend, a couple grand on wheels, tires, cage, outfitting the car (doing the work yourself, of course), plus the purchase price of the car. my combo is a 496 "a" body. 10.33:1, ported (by me) edelbrock closed chamber heads, 509 cam, 1.6 rockers, mighty demon carb, m1 intake, hooker super comp 2" primary fenderwells, dual 3.5 exhaust, moser 60, 3.73 with spool, 35 spline, 30" tall m/t et streets, 727 with lots of billet from crt, tci ultimate street fighter convertor 4400 stall (there's close to a grand right there- don't skimp on your convertor!), 3.5 dom steel drive shaft, forged solid 1350 u joints, 10 point cage, street legal with working horn, lights, wipers, and it runs easy tens all day long. i drive it to the track (50 miles each way).
Re: Low, low budget 10 sec rides [Re: maximum entropy] #958313
03/25/11 12:55 PM
03/25/11 12:55 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Well damn - its not that difficult.
In high school I had a dart
To save money put in a roll bar that was sitting at a local shop forever and got a good deal on it. It was for a 69 camaro and the measurements all worked out.
Car was all steel with plexiglass windows (couldnt afford lexan)
440 with 11.5:1 TRW pistons, steel 452 heads with home port job (I probably hurt them more than anything)torker intake, stock ignition, 850 holley DP
727 with shift kit, and some worn out used converter someone gave me
Cheap fiberglass seat, all interior stripped, alum dash, pro stick shifter
8.75 rear for A body with stock axles redrilled by Moser. Swap meet wheels, no spool in rear, 5 gallon fuel cell and batteries in trunk.
Stock leaf springs with pinion snumbber
Car weighed 2850 without me. So at the time 3000....car was very capable of high 10s in good air. Not knowing anything, and being a broke ass high school kid I was happy as hell.
It even looked pretty good. Just was NOTHING fancy or NOTHING that wasnt needed. Everything was boughten at swap meets, traded with friends or was given old worn out parts. Hell the trans just had a shift kit in it.
1.50 sixty foots, with posi and stock rear leafs, we added some extra leafs to beef it up. No idea if that helped or hurt....LOL
Sold that car rolling for 1500 bucks.
Re: Low, low budget 10 sec rides [Re: Garceau] #958314
03/25/11 01:15 PM
03/25/11 01:15 PM
gregsdart Offline
gregsdart  Offline
A guy I used to race against had what I beleive to be the cheapest 10.00 bracket car in existance. A well used roadster drag car, and a bone stock Buick 430 with nothing more than a cam in it. All the guy had in it other than stock may have been a converter and slicks?
Had I the need, I would hunt for a used roadster, a running boneyard 400, cast iron intake, thermoquad and all. A spare 340 converter, (in the shed) stock heads with valves back cut, a mild cam, reworked carb,some cheap headers, and have a ball. A two step and line lock, and you are in business!
Re: Low, low budget 10 sec rides [Re: maximum entropy] #958315
03/25/11 01:26 PM
03/25/11 01:26 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
Im with you. Maybe you can do it for cheaper but it wont last long and might not be real safe.
67' charger 499 RB 10.57 at 127
Re: Low, low budget 10 sec rides [Re: dragram440] #958316
03/25/11 03:14 PM
03/25/11 03:14 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Lets step it up... cheap, heavy B body, stock stroke low deck.
Re: Low, low budget 10 sec rides [Re: Eric] #958317
03/25/11 05:36 PM
03/25/11 05:36 PM
Australia
Charger VJ RB Offline
Australia
Whoa that is impressive. Just out of interest what was that combo turning rpm across the line.
Ford and Chev racers must of thought you where running a shot
RB XE274H Q-850
Re: Low, low budget 10 sec rides [Re: Charger VJ RB] #958318
03/25/11 06:23 PM
03/25/11 06:23 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
There is a guy in my area that has built 4-5 super low-buck "cars" that have run well into the 10's. They are welded up from scratch and end up looking like an altered, or a front-engine dragster with the rear end behind the driver. Usually 302 Ford power. Weight is probably less than 1500.
Re: Low, low budget 10 sec rides [Re: 6PACMAC] #958319
03/25/11 07:07 PM
03/25/11 07:07 PM
QLD Australia
Keith Black® Offline
QLD Australia
... low dollar 10 second cars ...
while you're at it please post pictures of your pet unicorns
Darren Beale
Keith Black Racing Engines®
Re: Low, low budget 10 sec rides [Re: Keith Black®] #958320
03/25/11 07:46 PM
03/25/11 07:46 PM
Lincoln NE
440forPOWER Offline
super gas
440forPOWER  Offline
super gas
Lincoln NE
I consider my 440 low budget for a 10 sec car. 440 stock crank and block, eddy rpm heads (highest dollar part) holley street dominator intake, (swap meet piece) 1000hp carb, 613 flat tappet cam. Best of 10.59 in a 70 bee. In a lighter a body I could see 10.0s or close. Fun for not a ton of money.
Re: Low, low budget 10 sec rides [Re: Keith Black®] #958321
03/25/11 08:17 PM
03/25/11 08:17 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
Why not lap giraffes too
http://www.petitelapgiraffe.com/index.php
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Low, low budget 10 sec rides [Re: 440forPOWER] #958322
03/25/11 08:27 PM
03/25/11 08:27 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
how much dos your car weigth
what compression
what gears /tire combo
1.39 9.85 - 137 mph
Re: Low, low budget 10 sec rides [Re: Charger VJ RB] #958323
03/25/11 08:29 PM
03/25/11 08:29 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Right around 6800..this is the car...
Re: Low, low budget 10 sec rides [Re: Eric] #958324
03/25/11 08:31 PM
03/25/11 08:31 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
and this is the motor after about 1000 passes with no freshen'....
Re: Low, low budget 10 sec rides [Re: Eric] #958325
03/25/11 08:31 PM
03/25/11 08:31 PM
tboomer Offline
tboomer  Offline
That one was a keeper,Eric!!
Page 1 of 3 1 2 3
