Re: Torrington Roller Thrust bearing for distributor gear?
[Re: Adrielp]
#958093
03/27/11 12:44 AM
03/27/11 12:44 AM
Posts: 52,972 Romeo MI
MR_P_BODY
What type of engine? BB- SB, Race, street?
650HP Race Engine for brackets only. My dad wants it to reduce wear. He showed me how much the bushing can actually wear into the shaft. It was pretty significant on the shaft we had so the shaft will be replaced and a new bearing will go in as well.
Sorry but I'm not understanding this... how will the torrington eliminate shaft wear(diameter) I'm just asking
[Re: Adrielp]
#958094
03/27/11 12:49 AM
03/27/11 12:49 AM
Posts: 18,428 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I think Dad worries to much. With a quality shaft you can just about bet that all you will need is a new 4.00 bushing at rebuild time.
[Re: TrWaters]
#958100
03/27/11 11:10 PM
03/27/11 11:10 PM
Posts: 307 OH
TheBlackCar
OH
If you are looking to mod this area, take a hacksaw blade and cut the groove in the bushing deeper and cut another one, like an x, before installing the bushing in the block. Also, lube the int shaft good when installing and you shouldn't experience those wear issues. Just because LS does something is definitely not a reason to do it! Quite the opposite. Good Luck
