Re: Dist Drive Shaft Bushing to Shaft Fit [Re: CHAPPER] #957417
03/24/11 09:56 PM
03/24/11 09:56 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Good to hear you got it. Beep
Re: Dist Drive Shaft Bushing to Shaft Fit [Re: Dabee] #957418
03/24/11 10:33 PM
03/24/11 10:33 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Right or wrong I fixed the problem. I have three new shafts so I tried each one. I also measured the shaft diameter of each one. There was about .001 to .0015 difference between the largest to smallest. The smallest diameter shaft would slip about 5/16 inch into the bushing before binding. I chucked this shaft up in my drill press and polished the shaft with 360 emery cloth for about 30 seconds followed by 600 sandpaper. The shaft went in about two inches before binding, so I gave it another 30 seconds. This time the shaft went all the way in with a nice sung fit. Thanks guys for all the good ideas.
You better loosen it up more than a good snug fit. At a good snug fit enough oil will not get to it and the bushing will eat the shaft. Once you have a snug fit ,in your case by making shaft smaller you need to remove another .0015
Re: Dist Drive Shaft Bushing to Shaft Fit [Re: qwkmopardan] #957419
03/24/11 10:59 PM
03/24/11 10:59 PM
Dandridge TN
Dabee Offline OP
Dabee  Offline OP
Dandridge TN
Good point, I'll measure it again in the morning and see if I need to take some more off.
Re: Dist Drive Shaft Bushing to Shaft Fit [Re: Dodgem] #957420
03/24/11 11:02 PM
03/24/11 11:02 PM
Dandridge TN
Dabee Offline OP
Dabee  Offline OP
Dandridge TN
I should come down to watch you run then we can go to Karls shooting!
Barry, Come on down. I need some more Canadian beer and we can do some shooting!
Re: Dist Drive Shaft Bushing to Shaft Fit [Re: Dabee] #957421
03/25/11 08:17 PM
03/25/11 08:17 PM
Brisbane Australia
raven Offline
raven  Offline
Brisbane Australia
i saw the correct tool for broaching this bushing at a machine shop & realised i could just press a ball bearing the right size thru with a nail punch. it works very well & extremely low cost. a tip i also was shown was before installation is to place the bushing between your thumb & forefinger, fill the bushing with oil & squeeze the oil until it seeped thru the bushing. this impregnated the lube into the bushing & apparently makes them last longer.
Re: Dist Drive Shaft Bushing to Shaft Fit [Re: Dabee] #957422
03/25/11 09:11 PM
03/25/11 09:11 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I'm thinking! Last light was down to 2F and supposed to be the same tonight! Ist a foot of snow this week now this cold spring my butt!
Re: Dist Drive Shaft Bushing to Shaft Fit [Re: Dodgem] #957423
03/25/11 09:15 PM
03/25/11 09:15 PM
Dandridge TN
Dabee Offline OP
Dabee  Offline OP
Dandridge TN
NHRA Nats are @ Bristol 17-19 June
Re: Dist Drive Shaft Bushing to Shaft Fit [Re: Dabee] #957424
03/25/11 11:13 PM
03/25/11 11:13 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Could do that maybe!
