Ohm range for Mopar fuel gauge sending units? #95640
07/27/08 06:08 PM
07/27/08 06:08 PM
Bowling Green KY / Nashville, ...
300by500 Offline OP
300by500  Offline OP
I'm looking for an aftermarket fuel level gauge, but I need to know what the ohm range should be for it to work in my '69 Barracuda. Anyone know?
Re: Ohm range for Mopar fuel gauge sending units? [Re: 300by500] #95641
07/27/08 06:47 PM
07/27/08 06:47 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Re: Ohm range for Mopar fuel gauge sending units? [Re: RodStRace] #95642
07/27/08 08:47 PM
07/27/08 08:47 PM
BDW Online content
BDW  Online Content
I always thought 5-10 ohms was the low side.
0-2 ohms would certainly explain why my 5V solid state version regulator couldn't supply enough current.
5V/1ohm = 5amps!
Re: Ohm range for Mopar fuel gauge sending units? [Re: BDW] #95643
07/27/08 08:58 PM
07/27/08 08:58 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
Autometer claims 73 ohms empty, 10 ohms full
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Ohm range for Mopar fuel gauge sending units? [Re: goldduster318] #95644
07/27/08 09:15 PM
07/27/08 09:15 PM
300by500 Offline OP
300by500  Offline OP
Yep.
http://store.summitracing.com/partdetail...mp;autoview=sku
Thanks for the help, y'all!
Re: Ohm range for Mopar fuel gauge sending units? [Re: 300by500] #95645
07/28/08 12:17 AM
07/28/08 12:17 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Moparaction.com might have some more info, but IIRC, then sending units in Mopars for fuel, oil, and temp were supposed to have 10 ohms for top of the scale, and 90 ohms for bottom of the scale.
Others more knowledgeable may chime in.
Keep us posted and pic'd on the Dakota junction box install...
-Marq
Re: Ohm range for Mopar fuel gauge sending units? [Re: MoparMarq] #95646
07/28/08 08:18 AM
07/28/08 08:18 AM
-Marq
nope, its 10 and 73 ohms. the new fuel sending units they are selling everywhere measure 10 and 90 though....
Re: Ohm range for Mopar fuel gauge sending units? #95647
07/28/08 10:55 AM
07/28/08 10:55 AM
Buffalo, MN
hydro Offline
super street
hydro  Offline
super street
Buffalo, MN
Yup, Its "10 to 73" but that's not all. The range is not linear across the sweep and the top and botton resistance can cause different results with different gauges. I have a fuel cell with the aftermarket sender (tube type) and it is nowhere near accurate. I'm on my 4th try at geting this thing re-calibrated so that the gauge reads somewhere near how much fuel is actually in the tank.
Re: Ohm range for Mopar fuel gauge sending units? [Re: hydro] #95648
07/28/08 01:47 PM
07/28/08 01:47 PM
Tampa, FL
Saint Crispan Offline
Tampa, FL
Well, you could always do it the hard way...
Put a gallon in, mark a line...put a gallon in...mark a line...
Might be long and tedious but durned accurate!
Re: Ohm range for Mopar fuel gauge sending units? [Re: Saint Crispan] #95649
07/28/08 04:06 PM
07/28/08 04:06 PM
Buffalo, MN
hydro Offline
super street
hydro  Offline
super street
Buffalo, MN
With the linear resistance sender a gallon can sweep the instrument panel gauge almost 1/4 tank!
Re: Ohm range for Mopar fuel gauge sending units? [Re: hydro] #95650
07/28/08 06:59 PM
07/28/08 06:59 PM
ddartdude Offline
ddartdude  Offline
Just checked the Miller C-3826 gauge checking tool and it's ------
L = 73.7 Ohms
M = 23.0 Ohms
H = 10.2 Ohms
M would be 1/2 a tank of gas.
