70 b-body turnsignal switch #955626
03/21/11 04:35 PM
03/21/11 04:35 PM
nesbit,ms.
70sate Offline OP
70sate  Offline OP
nesbit,ms.
witch wires should be 'hot' with key on,i have erm.4/ways,nothing hot on signals,or flasher on the turn signal side.is a new switch,n fuse test ok.
Re: 70 b-body turnsignal switch [Re: 70sate] #955627
03/21/11 05:13 PM
03/21/11 05:13 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
You have two flashers one for ts and a different one for emergencies. Have you checked both?
Re: 70 b-body turnsignal switch [Re: stumpy] #955628
03/21/11 06:03 PM
03/21/11 06:03 PM
nesbit,ms.
70sate Offline OP
70sate  Offline OP
nesbit,ms.
yes i checked,no power at turn signal flasher,should it have power on one side or does it come hot from the signal switch?
Re: 70 b-body turnsignal switch [Re: 70sate] #955629
03/21/11 07:42 PM
03/21/11 07:42 PM
Grand Prairie,Texas
Grand Prairie,Texas
No the power goes to the switch from the flasher and it should be hot on both sides. The turn signal switch is actually a ground circuit through the bulbs. When you put the switch to one side or the other the power goes from the flasher through the ts switch to the bulbs that complete the circuit to ground causing resistence. The flasher which is a bimetallic switch then heats up and the contacts seperate and that breaks the circuit until the flasher cools very quickly and makes contact again and send power to the switch. It does that over and over until the TS switch is shut off and breaks the ground loop. Double check the fuse to be sure you have power at both ends. The fuse contacts may be dirty and not staying in contact under use.
Re: 70 b-body turnsignal switch [Re: stumpy] #955630
03/22/11 11:15 AM
03/22/11 11:15 AM
nesbit,ms.
70sate Offline OP
70sate  Offline OP
nesbit,ms.
ok,that sounds like the advise i need,i'll try it this pm.will get back too ya,thank you
Re: 70 b-body turnsignal switch [Re: 70sate] #955631
03/22/11 06:27 PM
03/22/11 06:27 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
you might also find this site handy - http://www.mymopar.com/66to71_wiring.htm
Re: 70 b-body turnsignal switch [Re: mikemee1331] #955632
03/24/11 01:40 PM
03/24/11 01:40 PM
nesbit,ms.
70sate Offline OP
70sate  Offline OP
nesbit,ms.
thanks man
