Gas Tank Strap "J" Bolts #955569
03/21/11 03:13 PM
03/21/11 03:13 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
71 Cuda. How in the heck do you get the bolt head into these key holes? I have 2 types of J bolts, 90 degree and one with a slight angle. The heads are the same size though and I just cannot get them in these holes. I rotated the bolt 180 degrees and still won't go in. I'd hate to enlarge the hole or shave the heads.
Grandma always said I had "hands of gold"!
Re: Gas Tank Strap "J" Bolts [Re: CHRGR69] #955570
03/21/11 03:56 PM
03/21/11 03:56 PM
Under My Car
Mopar_Country Offline
Under My Car
If this is a tab that hangs down try putting it in from the threaded end.
Re: Gas Tank Strap "J" Bolts [Re: Mopar_Country] #955571
03/21/11 04:01 PM
03/21/11 04:01 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Try putting it in from the threaded end.
These are blind holes.
Re: Gas Tank Strap "J" Bolts [Re: CHRGR69] #955572
03/21/11 04:02 PM
03/21/11 04:02 PM
Under My Car
Under My Car
OK, mine has tabs that hang down.
Re: Gas Tank Strap "J" Bolts [Re: CHRGR69] #955573
03/21/11 05:22 PM
03/21/11 05:22 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Screw it I put the bolt to the grinder and made the top and bottom flat. Left the sides round and viola they fit securely.
Re: Gas Tank Strap "J" Bolts [Re: CHRGR69] #955574
03/23/11 05:37 AM
03/23/11 05:37 AM
Lost in the ozone again
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
Yea, I've had to do the same myself. Besides, who's going to see it anyway?
