727 intermediate band lever #955098
03/21/11 10:49 AM
03/21/11 10:49 AM
PA
BTTG Offline OP
BTTG  Offline OP
PA
If my installed lever is a 2.9 ratio and the trans is out of my car now is this something I definitely want to change or is the 2.9 fine to stick with (69 R/T stockish 440/727)? IF i should change where do you get these?
Also was going to put a transgo TF2 kit in while the tranny is out if I can gain enough confidence to do so (instructions in the kit are a bit vague/confusing to a novice).
Re: 727 intermediate band lever [Re: BTTG] #955099
03/21/11 10:54 AM
03/21/11 10:54 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You'll want to switch to a 3.8 lever, contact John Cope at CRT for one.
Re: 727 intermediate band lever [Re: JohnRR] #955100
03/21/11 11:57 AM
03/21/11 11:57 AM
PA
BTTG Offline OP
BTTG  Offline OP
PA
independent of any other changes what would the change from the 2.9 to the 3.8 lever do?
Re: 727 intermediate band lever [Re: JohnRR] #955101
03/21/11 06:34 PM
03/21/11 06:34 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I believe the 3.8 lever is considered stock for a BB applications. There is also a 4.2 lever and a 5.0 lever available. The 5.0 lever is sorta overkill for a street-car. It's considered by most a race only modification. However, If you're doing a TF-2 kit, I'd most definately go to the 4.2 lever. It just puts that much more pressure to the 2nd gear band apply. I run one in my 727 with a TF-2 kit, behind a 451, and it shifts firm but not annoyingly harsh.
Not to step on JohnRR's advice, the 3.8 will work just fine, I just think if you're gonna change it, I'd suggest the 4.2.
Re: 727 intermediate band lever [Re: StealthWedge67] #955102
03/21/11 08:56 PM
03/21/11 08:56 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
IMO the 4.2 is the best lever to use for any performance application.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 727 intermediate band lever [Re: dusturbd340W5] #955103
03/25/11 02:25 PM
03/25/11 02:25 PM
North Central Indiana
C-Tech Offline
C-Tech  Offline
My buddy may have some 5.0 levers for sale
Kevin
Re: 727 intermediate band lever [Re: C-Tech] #955104
03/25/11 03:23 PM
03/25/11 03:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
5.0 is not a good lever , especially for a street car with an automatic shift VB
Re: 727 intermediate band lever [Re: dusturbd340W5] #955105
03/30/11 09:21 AM
03/30/11 09:21 AM
C-Tech Offline
C-Tech  Offline
He has some of those as well
Kevin
