Page 3 of 3 1 2 3
Re: Coan super sprag for street, strengths/drawbacks? [Re: 440Jim] #954659
10/15/11 09:20 PM
10/15/11 09:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Back to the topic at hand... (please)
John,
Does the A&A Ultimate Sprag use 1/4 bolts with compression ferrels?
The Coan says it uses 8mm shoulder bolts, and the case bolt holes need to be enlarge since that is slightly larger than the stock 727 5/16 bolts that thread into the case (not the sprag).
Sorry Jim I missed this question the first time around ....
Yes the A+A uses the 1/4" bolts and ferrules , I also machine the case and add the 2 extra bolts that the A+A allows you to use because it is a 6 bolt.
Re: Coan super sprag for street, strengths/drawbacks? [Re: JohnRR] #954660
10/15/11 10:22 PM
10/15/11 10:22 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
some good info guys,thanks!
Re: Coan super sprag for street, strengths/drawbacks? [Re: Clanton] #954661
10/15/11 11:33 PM
10/15/11 11:33 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
For what it's worth, those shoulder bolts from Coan are not the best. The broach of the internal hex, is iffy, at best. The last one I used (3rd unit), I made my own spacers, out of steel tubing (like I have since 1978). MUCH better fit, and no worries about stripping the internal hex for the next builder to hassle with. Also, I personally don't see the need to add the extra 2 bolts. Any application that can sheer off 4 bolts, should have a low band apply V/B anyway.
Re: Coan super sprag for street, strengths/drawbacks? [Re: Leigh] #954662
10/16/11 01:32 PM
10/16/11 01:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Leigh I just do it for piece of mind knowing it's still bolted tight if you have to pull the rear drum /gov. support , takes about 20 mins in the bridgeport , drill 2 holes and spot face.
I like your fix with the steel tubes, I think someone did something similar with brake line ?
Re: Coan super sprag for street, strengths/drawbacks? [Re: Leigh] #954663
10/17/11 01:29 PM
10/17/11 01:29 PM
NC
440Jim Offline
440Jim  Offline
NC
Thanks for the info/experience.
Did you use 1/4 bolts instead of the shoulder bolts and drill the case to 5/16 and make a sleeve to fill the case and fit the 1/4" bolts nicely?
Is the Coan race tapped 1/4-28?
The shoulder bolts look like a good idea, but if the hardware is marginal, that defeats the improvement. Although I don't like the compression ferrels to fit smaller (i.e. 1/4") bolts into the case, I have never heard of any problems with them. And many standard bolt-in sprags use that method.
Re: Coan super sprag for street, strengths/drawbacks? [Re: JohnRR] #954664
10/17/11 06:32 PM
10/17/11 06:32 PM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
Bottom line: your sprag is less likely to fail if it's a bolt-in. They're not that expensive and there really is no drawback in using one.
Only half correct , The facory type sprag wit ha bolt in outer race will still fail by having the rollers rollover , the Cona or A+A sprag has more rollers so it is virtually impossible to have the rollers fail.
Just replacing the outer race to a bolt in type on a trans that has not had the outer race spin in the case is a waste of time and money.
You make a good point about the roller rollover, but even if the outer race has never been spun, installing a bolt-in sprag will still lessen the chance of it ever spinning (the force required would need to be much greater).
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Page 3 of 3 1 2 3
