Big Block or Gen III Hemi? #954162
03/20/11 12:59 AM
03/20/11 12:59 AM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
After lurking here as an unregistered guest for several years, and then still lurking as a registered member for a few more, I've come to the conclusion that there are some very smart people on this site. With that said, I've decided I'm ready to solicit some opinions. I'm getting ready to finally start construction on my "bucket list" race car. My question is: If you were going to build a tube chassis car, and had pretty much no parts at this time, would you build a 500+inch wedge or a gen III Hemi? Max horsepower expectation would eventually be about 900hp, but not for a few years.
Re: Big Block or Gen III Hemi? [Re: cagebob1] #954163
03/20/11 02:43 AM
03/20/11 02:43 AM
I'm a old wedge guy from way back so my choice, based on personel expereinces would be the 500+ C.I. wedge, probally 4.500 bore by 4.250 stroke with a new race block and a real good set of heads, B1 or Predators. You really should make a decision on which motor to use before buying any partsThe new Gen3 Hemi have the potential to make a lot of power also The choice is yours to make
Re: Big Block or Gen III Hemi? [Re: cagebob1] #954164
03/20/11 10:02 AM
03/20/11 10:02 AM
NC
440Jim Offline
440Jim  Offline
NC
Good question.
Are you considering a ProCharged, or supercharged Gen III?
I think it will still be cheaper and easier to build a 511-572 CID, B1 headed, big block wedge. Get a 4.500" bore World (MP) block (aluminum if you have the money), 4.25-4.50" stroke crankshaft, and some B1 original heads and you have 900 hp for roughly $15,000.
But the Gen III would be really cool, light weight, etc. And I think with a small ProCharger or supercharger it could be the future.
Re: Big Block or Gen III Hemi? [Re: 440Jim] #954165
03/20/11 12:50 PM
03/20/11 12:50 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Old School will be cheaper. And easier not to screw up and make a $$$ mistake. There is lots more knowledge around on the old motors.
Id build a wedge using an aftermarket 4.5" block some Indy or B1 heads.
Re: Big Block or Gen III Hemi? [Re: cagebob1] #954166
03/20/11 02:28 PM
03/20/11 02:28 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
If it`s your "bucket List" car, why not go Gen II Hemi ? I did , and have never regretted it .
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Big Block or Gen III Hemi? [Re: chryco] #954167
03/20/11 06:41 PM
03/20/11 06:41 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
Thanks for the input!
Cab - I'm a big block wedge guy from way back also. I know how easy it is to get stuck in the past, and feel that I must at least consider new technology ( distributor less ignition and EFI ).
Jim - I'm not opposed to the idea of forced induction down the road if that's what it takes to get the power desired, and I agree that it would have some cool points!
domingo- No doubt about fewer new trails to blaze and the opportunity for expensive mistakes
Chryco - Isn't a Gen II Hemi really expensive?
Re: Big Block or Gen III Hemi? [Re: cagebob1] #954168
03/20/11 07:59 PM
03/20/11 07:59 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Old BB stuff is cheaper and easy to copy someone elses build , HOWEVER if I could sell my 3-race motors and my 11-spare 440`s/parts etc.... I would be building a new HEMI with a pro-charger like tommorrow!!!!!!!
I`ve been intrigued with the new stuff for quite a while.
To me the old stuff is just that "old".
Either way do what you think will satisfy your needs.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Big Block or Gen III Hemi? [Re: cagebob1] #954169
03/20/11 08:40 PM
03/20/11 08:40 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Easier and cheaper would be a boosted wedge.
Coming soon!!!!
Re: Big Block or Gen III Hemi? [Re: cagebob1] #954170
03/20/11 09:23 PM
03/20/11 09:23 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
How fast do you want to go ?
Re: Big Block or Gen III Hemi? [Re: chryco] #954171
03/20/11 09:44 PM
03/20/11 09:44 PM
gregsdart Offline
gregsdart  Offline
If your goal is 900 hp in the future, the cheapest route is to start with those parts. You can do it with B1 heads, or 572-13 heads, or even 440-1 heads. But the latter is going to require that you have all the tricks to get there. that equals $$$. My cheapest recipe would be to locate a used set of B1 heads that flow well ( good porting work) and put them on a 540 557 or 572 shortblock. The deal won't have to be real exotic to get 900 hp.
Re: Big Block or Gen III Hemi? [Re: cagebob1] #954172
03/20/11 10:23 PM
03/20/11 10:23 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
BONDO BOB had a killer hemi for sale,maybe still does
Re: Big Block or Gen III Hemi? [Re: fishy340] #954173
03/21/11 10:29 PM
03/21/11 10:29 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
What car are you putting it in?
Re: Big Block or Gen III Hemi? [Re: 6bblFLASH] #954174
03/21/11 10:34 PM
03/21/11 10:34 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
If I were to do it from scratch....id do this
http://musclemotorsracing.com/engines/king-krate.html
Re: Big Block or Gen III Hemi? [Re: fishy340] #954175
03/21/11 10:36 PM
03/21/11 10:36 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
That HEMI was a heck of a deal, dirt cheap!!
I would go with the new Gen 3 HEMI!
people have proved its not hard to make the power with them.
I regret building another LA motor instead of the newer HEMI!
Re: Big Block or Gen III Hemi? [Re: HEMIDARTS] #954176
03/21/11 11:38 PM
03/21/11 11:38 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
The chassis for this project is to be a light weight tube chassis (Dave Morgan would call it a ballerina)...RX7. Yea, I know it's not a mopar body, but it was free, and besides that, it should be good for aggravating the ricers! My ultimate goal is to run a 7.99 et, hence the 900hp goal...down the road a few $$$$. The Gen III Hemi looks to have a lot of potential and I think it would be cheaper and lighter than a Gen II Hemi, or at least smaller! That's why I'm looking for opinions
Re: Big Block or Gen III Hemi? [Re: cagebob1] #954177
03/22/11 08:11 AM
03/22/11 08:11 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
WOW! If the budget allows in something that light and small I would say Gen-3
Re: Big Block or Gen III Hemi? [Re: cagebob1] #954178
03/22/11 08:23 AM
03/22/11 08:23 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
The Gen III would be cheaper and lighter/smaller than Gen II. They do make some good power adders for them now. You going to run it N/A? Boost? Spray?
Re: Big Block or Gen III Hemi? [Re: Mr.Yuck] #954179
03/22/11 09:54 AM
03/22/11 09:54 AM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
the plan would be to run it n/a, but I'm not opposed to a procharger if that's what it takes to achieve to reach my goals.
Re: Big Block or Gen III Hemi? [Re: cagebob1] #954180
03/22/11 10:05 AM
03/22/11 10:05 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think in the long run it would be cheaper and make a more reliable car. With boost you don't need to wind the pee out of the engine, use big lift cams, huge stalls or tall gears. My buddy runs a Plymouth TC3 (omni) chassis car. He has a W5 headed 392 SB. He uses 10-12lbs of boost (big turbo, no inner-cooler) 4200 stall and 3.73 gears. He has run 8.20's at 175. The car could run 7's if he jumped up the boost and wanted to use the trans brake.
Re: Big Block or Gen III Hemi? [Re: Mr.Yuck] #954181
03/22/11 10:19 AM
03/22/11 10:19 AM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
That's the type of feedback I was looking for. I've always been a N/A big block guy, but I think it's time to embrace the new technology
