Re: Centering rear end in chassis, anyone done this *DELETED* [Re: NachoRT74] #953875
03/21/11 11:54 AM
03/21/11 11:54 AM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
Post deleted by BradD
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: Centering rear end in chassis, anyone done this [Re: BradD] #953876
03/21/11 12:06 PM
03/21/11 12:06 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Your whole drive line is off center to the right!! They were built this way. It was so the car would be better balanced with a driver behind the wheel.
Brad
That would make sense if the right side is tight.
This one is tight on the left rear.
They just didn't have tight tolerances back then.
Re: Centering rear end in chassis, anyone done this [Re: RodStRace] #953877
03/21/11 01:17 PM
03/21/11 01:17 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
How is your alignment of the trans yoke centerline to the pinion yoke centerline , are they in line or is the rear shifted to the left?
The reason the driveline is off center is to give the driver a little more room in the passenger compartment I would think.
Re: Centering rear end in chassis, anyone done this [Re: JohnRR] #953878
03/21/11 01:46 PM
03/21/11 01:46 PM
Riverside, California
ghostrider Offline
ghostrider  Offline
They are offcenter to the passenger side for clearance around the steering gearbox that is on the leftside.
Must remember... my humor doesn't work on forums.....my humor doesn't work on forums. Former Mopars include 69 Super Bee, 71 Sebring, 68 Charger, 69 Charger, 78 D150, 67 300, 71 Road Runner clone, 79 T-top Doba, 67 Barracuda, 91 TC by Maserati, 68 Town & Country
Re: Centering rear end in chassis, anyone done this [Re: MileHighDart] #953879
03/21/11 03:49 PM
03/21/11 03:49 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Heres the Drivers side, Measures 3/8" clearance.
Was that 1/4 replaced recently? If so, perhaps the lip wasn't shortened. They do require trimming, specially the 1/4 skins.
Re: Centering rear end in chassis, anyone done this [Re: Pntastar69] #953880
03/21/11 03:59 PM
03/21/11 03:59 PM
Lyons, CO
MileHighDart Offline OP
Lyons, CO
No, the car is all original, no new sheet metal
Re: Centering rear end in chassis, anyone done this [Re: MileHighDart] #953881
03/26/11 12:50 AM
03/26/11 12:50 AM
pass christian, ms
69fish Offline
69fish  Offline
pass christian, ms
I don't have anything to add to the discussion-I just wanted to say those wheels really "woke" your car up. It looks like a different car-looks great!
Re: Centering rear end in chassis, anyone done this [Re: 69fish] #953882
03/26/11 01:22 AM
03/26/11 01:22 AM
Under My Car
Mopar_Country Offline
Under My Car
Did you come to a conclusion on the spacing?
Re: Centering rear end in chassis, anyone done this [Re: MileHighDart] #953883
03/26/11 01:38 AM
03/26/11 01:38 AM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
I'm sure glad you didn't get any paint on Elvira when you stabbed that rattle can to death.
I have nothing else to add.
Down to just a blue car now.
Re: Centering rear end in chassis, anyone done this [Re: Mopar_Country] #953884
03/26/11 02:20 AM
03/26/11 02:20 AM
Lyons, CO
Lyons, CO
Not a conclusion really, But I do think its more of an issue of the body panels being a little different from one side to the other rather than the rearend being offset in relation to the frame rails.
I just got the new green bearings for my new bbp axles yesterday and finally have it assembled so I can really see where the wheels are going to set.
I also trimmed the width of the fender lip on both sides by a little over 1/8". Laid it out with masking tape, and ground off a little with a disk sander and a 50grit disk.
I think I can live with the clearance I have now, although it is still different from one side to the other.
I have about 1" clearance on pass side, and now have about 1/2" on the drivers side. So I guess I'm not going to worry about moving the rear for now.
This is how the drivers side looks with the lip trimmed back a little.
Re: Centering rear end in chassis, anyone done this [Re: 69fish] #953885
03/26/11 02:24 AM
03/26/11 02:24 AM
Lyons, CO
Lyons, CO
Thanks !
Actually it really does look different now, since its about 1/2 primered, getting it ready for new paint. But I agree with you, the wheels really look sweet, better than the rallys I took off.
Re: Centering rear end in chassis, anyone done this [Re: MileHighDart] #953886
03/26/11 02:26 AM
03/26/11 02:26 AM
Lyons, CO
Lyons, CO
another pic just to show off a little.
