Re: Edelbrock fuel injection
[Re: Jim_Lusk]
#953473
03/19/11 12:28 PM
03/19/11 12:28 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
About 8 years ago I worked with a guy who had it on his truck. It worked pretty good and he had great customer service.
68 Barracuda Formula S 340
[Re: Jim_Lusk]
#953475
03/19/11 02:46 PM
03/19/11 02:46 PM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
They start at just over $3,000 at Summit. The XT system is a little over $4,000. There aren't very many people who will spend that kind of money for injection, but there are some.
For 100th of the money ... you can tweak a PlasticFantastic !
[Re: moparmojo]
#953477
03/19/11 04:29 PM
03/19/11 04:29 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I think I would use the intake, injection hold down, throttle body and maybe some of the sensors but that would be it.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: GetAwayDriver]
#953478
03/19/11 05:19 PM
03/19/11 05:19 PM
Posts: 3,078 Edmonton, Alberta, Canada
Dartman75
Yeah, I'd like to know more about it too... Edlebrock quality so far above the Holley systems no doubt! What's a ball-park cost? Is that intake too tall to clear most standard hoods?
I don't think it will be a problem to clear hoods. When you have no carb, no air cleaner up top etc. A tunnel ram style intake can work quite well. The front where the throttle body goes needs to angle down which starts to interfer with water plumbing etc, but on the whole not problems.
This is my Small block 408 under the hood of my 75 dar with around 1/2" clearance on the closest partright at the throttle body.
The only close-up pic I have already on the web: http://www.telusplanet.net/public/zbhansen/temp/HydroboostFromSide.JPG
Mine is a Weiand SB tunnel ram base with a custom made plenum.
