Hyd Race Lifters #949900
03/13/11 03:11 PM
03/13/11 03:11 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Anyone running the Johnson type race Hyd lifters. What are you using for preload. I have seen conflicting settings; at the moment I have 1/3 of a turn preload. Some say they should be set at zero to 1/16 of a turn. Thanks for your input; these lifters have the HD circlip in the body rather than the wire retainer.
Re: Hyd Race Lifters [Re: Hemi_Ram] #949901
03/13/11 03:17 PM
03/13/11 03:17 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
I've run them with 1/8 turn which worked out to about .005 preload for me. I would not be afraid to try 1/16, you may get a little noise until it warms up.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Hyd Race Lifters [Re: Hemi_Ram] #949902
03/13/11 06:57 PM
03/13/11 06:57 PM
Washington, Pa
runner12 Offline
runner12  Offline
Washington, Pa
Hughes sells hi lift johnson lifters . on there web site the give instructions for rv -4x4 street and race.
Re: Hyd Race Lifters [Re: Hemi_Ram] #949903
03/14/11 12:30 AM
03/14/11 12:30 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
I believe Johnson Hylift sources these lifters to Comp Cams which repackages them as the Comp Cams Pro Magnum Lifters
Lifter preload should be set to .002”-.004” (hot settings) - LINK
Best deal on Johnson Hylift lifters: https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=5650281&Main=5649254
