Removed speedo cable #949854
03/13/11 02:12 PM
03/13/11 02:12 PM
Raleigh, NC
rockerbob Offline OP
Raleigh, NC
I removed the speedo cable from my 69 Satellite 904 tranny. Since I installed a custom sheet metal dash I no longer need it. Now I have a slow drip. Should I plug it or is that as bad as it will drip & be fine.
2005 Dakota 4X4 3.7 2004 Rumble Bee 5.7 1978 Diplomat 318 1969 Satellite 318 "bracket racer" 1966 Barracuda (in progress ) 1964 Dodge 330 (future race project) 1962 Belvedere (HUM????)
Re: Removed speedo cable [Re: rockerbob] #949855
03/13/11 02:16 PM
03/13/11 02:16 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
It'll get worse.
Make a small sheetmetal cover and install it over the hole.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Removed speedo cable [Re: rockerbob] #949856
03/13/11 02:17 PM
03/13/11 02:17 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Take the speedo cable/gear adapter out of the trans, remove the gear, find a bolt that is long enough to extend through & have a nut fit on the end.... Clean everything up, coat the bolt with sealant, insert into the adapter, install & tighten nut.. Reinstall the adapter.... No more leak...
Re: Removed speedo cable [Re: 1_WILD_RT] #949857
03/13/11 03:12 PM
03/13/11 03:12 PM
Nova Scotia Canada B2Y 1E4
SANDYinNS Canada Offline
Measure the size of the hole witth the adpter out ..get a frost/core plug and drive it into the tranny no more leak nice clean looking job
Sandy in Nova Scotia formerly drdodge340
68 coronet wagon, 68 formula s 340 fb barracuda-69 super bee-72 aussie charger-72 aussie vh dodge ute
-76 feather duster-76 duster-77 street van
- 98 ram 1500 SS/T-99 ram 1500-13 ram red express truck- 2015 hellcat challenger
Re: Removed speedo cable [Re: rockerbob] #949858
03/13/11 04:07 PM
03/13/11 04:07 PM
Raleigh, NC
Raleigh, NC
Mine has a large nut on the end of the cable. Took a 1" wrench to remove. Left a male threaded stub. Can I just go to the local hardware store & buy a brass fitting/pipe plug to thread over it?
Re: Removed speedo cable [Re: rockerbob] #949859
03/13/11 04:16 PM
03/13/11 04:16 PM
michigan
sturmenater Offline
sturmenater  Offline
michigan
Remove speedo gear tap the housing its self were gear and shaft go through than instal plug install plug. Just did this myslef cant rember I thing i tapped it 1/4 npt
Re: Removed speedo cable [Re: sturmenater] #949860
03/14/11 10:23 PM
03/14/11 10:23 PM
moparx Offline
moparx  Offline
i have threaded caps with neoprene gaskets that seal on the speedo gear housing. pm me if interested.
Re: Removed speedo cable [Re: rockerbob] #949861
03/14/11 10:29 PM
03/14/11 10:29 PM
yes if you can match the thread type, should b able to
Re: Removed speedo cable [Re: RapidRobert] #949862
03/14/11 10:50 PM
03/14/11 10:50 PM
moparx Offline
moparx  Offline
thread size is 7/8-20. not a real popular size.
Re: Removed speedo cable [Re: moparx] #949863
03/15/11 09:01 AM
03/15/11 09:01 AM
Raleigh, NC
Raleigh, NC
Let me check with one of the local hardware stores first. We have 4 right here in this dinky small town (Youngsville). 1 Farm, 1 plumbing & 2 general hardware. Hopefully one will have something I can use. If not I may contact you. Thanks.
Re: Removed speedo cable [Re: rockerbob] #949864
03/15/11 09:33 AM
03/15/11 09:33 AM
scratchnfotraction Offline
they have new o-rings for the speedo pinion shaft
I replace those and clock the speedo plug so the gear does not turn the pinion
this will save it for a future speedo hook up
if you look at the plug it has #s on it to match up with the plastic gear for it to clock in the tail housing just set it so it does not mesh up the gear and it wont be turning to wear the o-rings out
if you use any sealent use the mopar ATF/RTV from the dealer,it holds up to tranz fluid for a long time
I have just removed the speedo pinion and filled the hole end to end with the ATF/RTV and let cure over night on the bench
