302 heads #949499
03/12/11 10:00 PM
03/12/11 10:00 PM
Nuevo leon,mexico,Monterrey
asesino Offline OP
asesino  Offline OP
Hi, I wonder how good are the heads 302 (4323302) and I put some on my 318 and I have heard positive and negative comments, I would like to know the fifferences between 302 and 308 (which are better) as they relate to burn fast as i was researching and a page read that thanks
xASESINOx
Re: 302 heads [Re: asesino] #949500
03/12/11 10:07 PM
03/12/11 10:07 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
From what I know ... the 302 head is the best MPG head ... but not much on HP.
Re: 302 heads [Re: dOOc] #949501
03/12/11 10:14 PM
03/12/11 10:14 PM
asesino Offline OP
asesino  Offline OP
What it means with MPG????
xASESINOx
Re: 302 heads [Re: asesino] #949502
03/12/11 10:21 PM
03/12/11 10:21 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
NOT sure what you are asking ??...??
It is a fast burn head .. like you said ....also great for A/F mixing(swirl) ... but THUS it is not a higher rpm good-flowing head.
There are some well-versed A engine guys on here that can maybe give you more detailed info on them.
Re: 302 heads [Re: asesino] #949503
03/12/11 10:22 PM
03/12/11 10:22 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
302 heads are a good, cheap way to get a little more hp and they are closed chambered which is a good way to bump compression. The 308 head is the same head but had bigger valves. these were used on the 360's. these heads are good performers with mild porting.
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: 302 heads [Re: dOOc] #949504
03/12/11 10:34 PM
03/12/11 10:34 PM
asesino Offline OP
asesino  Offline OP
sorry bro, i meant to your answer to MPG, i don't have familiarized with this term, what it means?
thanks
xASESINOx
Re: 302 heads [Re: asesino] #949505
03/12/11 10:49 PM
03/12/11 10:49 PM
miles per gallon. I have a set but haven't done anything w them yet. You have a closed chamber which'll give you more CR plus quench if you build for it (I would & definitely on a mileage 318 build). Did a little reading on them & bowl hog (forgot the angle) and going from the 1.78 to a 1.88 valve was recommended & mild porting/deburring is always beneficial
Re: 302 heads [Re: mopars_1] #949506
03/12/11 10:52 PM
03/12/11 10:52 PM
asesino Offline OP
asesino  Offline OP
Then, a 360 with 308 heads and hypereutectic pistons to increase the compretion its better,, well i think ,Don't???
xASESINOx
Re: 302 heads [Re: RapidRobert] #949507
03/12/11 10:57 PM
03/12/11 10:57 PM
asesino Offline OP
asesino  Offline OP
hahaha , thanks i understand now, well i must convert milles to km, thanks
xASESINOx
Re: 302 heads [Re: asesino] #949508
03/12/11 11:07 PM
03/12/11 11:07 PM
multiply miles by 1.609344
Re: 302 heads [Re: mopars_1] #949509
03/12/11 11:15 PM
03/12/11 11:15 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
The 308 head is not the same as the 302 with bigger valves.
As said, the 302 is a closed chamber head, that will give you an easy compression boost on a 318.
The 308 is an OPEN chamber head, just like any other 360 head. It is the best flowing iron head until the 1992 Magnums came into production. The main improvement over the earlier 360 heads is the exhaust port design. Downside, is that installing the 308 (or any 360 head) is going to drop your already low 318 compression even lower.
For a low budget, mild build, go with the 302's. If you have money to mill the deck, upgrade pistons, then go with the 308's. The 308's are typically much harder to find than the 302's.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 302 heads [Re: mopars_1] #949510
03/12/11 11:15 PM
03/12/11 11:15 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
#08 heads are most definately NOT the same as 302's with larger valves, not even close. 308's are 360 type heads with all that entails, not 318 heads with bigger valves.
Don't be the exception.
Re: 302 heads [Re: GO_Fish] #949511
03/12/11 11:18 PM
03/12/11 11:18 PM
Re: 302 heads [Re: RapidRobert] #949512
03/13/11 03:23 AM
03/13/11 03:23 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
http://www.moparts.org/Tech/Archive/smallblock/23.html
When I was first getting into the hobby, a lot of the articles in the tech archive here hastened my learning. Especially this one pertaining to small block cylinder heads.
Re: 302 heads [Re: MarkZ] #949513
03/13/11 06:57 PM
03/13/11 06:57 PM
asesino Offline OP
asesino  Offline OP
thanks for all your answers, and betwen the 308 and magnum heads. which is best??
xASESINOx
Re: 302 heads [Re: asesino] #949514
03/13/11 06:58 PM
03/13/11 06:58 PM
magnum
Re: 302 heads [Re: RapidRobert] #949515
03/13/11 07:21 PM
03/13/11 07:21 PM
asesino Offline OP
asesino  Offline OP
what kind of camshaft have a 69 340 ,because i want put one or similar in a 360 w magnum heads and hypereutectic pistons,,, how so good it is??
xASESINOx
Re: 302 heads [Re: asesino] #949516
03/14/11 09:34 AM
03/14/11 09:34 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
the 308's are essentially a smog 360 head with a magnum exhaust port. the bigger pushrod pinch needed for the roller lifter's poorer pushrod angle induced some swirl into the ports.
the 302 is a closed heart shaped chamber, small valve 318 head. good for compression, but it flows as poor as any 318 head. max ported with bigger valves, they flow about the same as OOTB magnums.
magnums outflow any stock head save the X's, which they about match on the intake side, but outflow on the exhaust. with a smaller port (more velocity, which means more torque). they also have a nice small closed chamber with dual quench pads.
2017 Grand Cherokee Overland
Re: 302 heads [Re: patrick] #949517
03/14/11 04:19 PM
03/14/11 04:19 PM
asesino Offline OP
asesino  Offline OP
Ok, then if i work the 302 heads almost the edge works like a magnum!!!????
xASESINOx
Re: 302 heads [Re: asesino] #949518
03/14/11 05:47 PM
03/14/11 05:47 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Asesino -
What are you building, a 318 or a 360? Do you want fuel economy or HP? Magnum heads or LA heads? (there are a bunch of parts you need to change for that conversion)
Until you specify, the answers you get may not be suitable for your goal. (a 'just build a 408' response is destined to happen soon )
